New Member Needs Help
Depends on your state requirements. Usually these cars are exempt from passing emissions tests but have to pass a visual inspection to ensure that you have the equipment on the car (even if it isn't operational). It is very common to have this stuff removed and depends on your state and even more on the inspector. My suggestion is to just take it in to a small station and see what they say. Many times they are run by kids too young to really know what they are looking for and since they don't have to test it they will slap a sticker on if your lights and all the basics are working. I've never had them pop the hood or look under the car to see the cats are gone. Your mechanic was RIGHT in what he told you but unless you are in California you will probably be ok. If you have the original breather just put the hose on it and let it hang for your inspection. Otherwise you will have to replace the headers with original exhaust manifolds.
As far as the parking brake, I'm not really understanding. It should ratchet up on the teeth by pulling up on the lever and all the button is spring loaded to allow it to release the brake lever. How are you manually engaging it? There is a cable attached to the brake lever and runs back under the car towards the rear. It the turns into a Y with a spring that gives the tension to the system and the cable turns into 2 cables that run one each to both back wheels. You will make adjustments down there. Could just need adjustments at the spring. Again it is not uncommon for the e brake not to hold very well after all of these years.
Trying to understand your question about the handle not moving the clip to the teeth, are you meaning that you have to pull the button out manually to hold it into place or are you trying to push the button to e engage the brake. To engage you should only pull the handle up. There should be a spring in the button that will extract the button when you stop applying pressure to it.
For example, here in Texas, my car has no inspection. I have no stickers on my windshield nor my license plate and I am only required to have a rear plate. I am not required to have a safety or emissions inspection. The down side of this approach is that you are only allowed to drive the car for parades, car shows and other public "exhibits".
As a result, my car is always on exhibit.
probably should have taken it to a gas station for the inspection, but ended up taking it to jiffy lube here in town. the mechanic really sounded like he knew what to look for even on an older car like this one. but, at the end of the day, I would like to make sure this car has no problems passing any further inspections.
There is a kit to adapt the hot air tube to headers. Very simple fix. Parking brakes are a little more involved.
Mike
