Weatherstrip advice
Old Feb 20, 2012 | 04:26 PM
19Tyler74's Avatar
19Tyler74
Default Weatherstrip advice
Hello,
Have some leaky seals either in the pillar area, or in the t tops.
Was wondering if anyone knew any tech articles on replacing these - or which kit was best for a coupe. I have seen some on ebay for cheaper than Ecklers and the like... but I don't want to cut a corner if it has the obvious potential to hurt in the long run.
Thanks.
Old Feb 20, 2012 | 04:59 PM
Alan 71's Avatar
Alan 71
Hi Tyler,
I read good reports here about the weatherstrips made by Corvette Rubber Company in Cadillac, Michigan. Also known as CRC.
Various vendors sell them, so ask who's made what you're buying to know whether you've gotten a competitive price.
There have been some weatherstrip installation threads in the last year or two. Have you done a search?
Good Luck!
Regards,
Alan
Old Feb 20, 2012 | 09:25 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Tyler-
The only weatherstrip I sell and install for c3 cars is CRC brand.
You really have to watch the ebay weatherstrip kits.. most are imported.
The most common issue I've seen with the imported rubbers are the ends on the coupe door mains, they are usually wrong. Another issue is the pillar is an extruded part (and hollow in the middle) with ends bonded on. The original part was a molded part from top to bottom.
The end section issue with the imported rubber is so common we actually changed our pictures to let people know the difference.
We have the CRC weatherstrips on the forum special price section at this link
http://willcoxcorvette.com/advanced_...s=weatherstrip
And if you do decide to order make sure to use the current sale coupon listed in the sale thread we are running.
Old Feb 20, 2012 | 09:33 PM
Mod75's Avatar
Mod75
2024 C3 of the Year Winner - Modified
I went with the CRC one form Willcox for my 75 coupe.
Good product, fit perfect. Have seen the ebay ones installed and did not think to much of them.
Old Feb 20, 2012 | 09:55 PM
ragtop00's Avatar
ragtop00
Willcox
Old Feb 20, 2012 | 09:57 PM
Peterbuilt's Avatar
Peterbuilt
It's a fairly easy, but slightly messy job.
Cover the interior, remove the old weatherstripping and clean what's left with "3M General Purpose Adhesive Cleaner",
Then test fit the new weatherstripping by taping it in place.
Then apply "3M Weatherstrip Adhesive".
Old Feb 20, 2012 | 11:21 PM
0Willcox Corvette
Former Vendor
The 3M cleaner is a must...
And get the pillar weatherstrip clips... you'll need to replace them! More than likely, the coating is gone off of them.
On a C3, don't waste money on the weatherstrip tool kit either... you can spend it on something else!
Old Feb 21, 2012 | 01:15 AM
Korevette's Avatar
Korevette
Prep, prep, check and prep again.
Trial fit and understand what you are doing. Many people get intimidated with this process and can end up with 6" more material by stretching and blame it on the manufacture.
There are "check points" with the secure 'pins and screws'. Use a marker and/or masking tape to document the interface point. Take your time, installation of most Corvette parts are at your pace, not someone elses.
Read, understand, test and apply - satisfactory results will be obtained.
Old Feb 27, 2012 | 12:11 AM
19Tyler74's Avatar
19Tyler74
Thanks a lot for the tips!
Thanks Willcox - will def but the kit through you!
Best regards!
Old Feb 27, 2012 | 12:27 AM
19Tyler74's Avatar
19Tyler74
@ Willcox - was looking to order a set for my coupe but could not find the coupon - please let me know!
To Weatherstrip advice
