Rebuilding a T5.
Old Feb 26, 2012 | 05:00 AM
thegavel's Avatar
thegavel
Default Rebuilding a T5.
Gooday all,
Got the chance to pick up a T5 box and assorted other bits
(some I wouldn't need anyway) for 50 bucks.
Seller tells me he took it to a local shop and they told him
the box looks great inside exept the reverse gear
is stripped.
So here's my questions...
Is this worth buying and having it repaired ????
Also, can a T5 internals be upgraded ????
I'm wanting to go 5 speed but I'm in no hurry,
if I did buy this, it would still be awhile before I'd be
installing it.
Just figured this might be a good place to start
(obtaining the parts I'll need).
Looking forward to your (always) helpful & humorous replies.
Gav
Old Feb 26, 2012 | 07:54 AM
Jeffsvettes's Avatar
Jeffsvettes
Is it a world class T5 ? They are stronger than the non world class. I think the WC T5 is rated about 350 HP. A new reverse idler gear is about $35-40.00. A full rebuild kit with everything except new gears costs about $300 +/-. They are very easy to rebuild and can be done in a few hours by most people with basic mechanic skills, tools and a dial indicator. You can even get a how to rebuild CD for under $20 if you never rebuilt a trans before.
Jeff
Old Feb 26, 2012 | 07:58 AM
aussiejohn's Avatar
aussiejohn
Default 50 bucks!!!???
Gav,
Where did you get this? I'd also like to go 5 speed, but my budget is well under a grand, which means I'll be staying 4 speed unless I can find a deal like that. From which car did it come?
Regards from Down Under.
aussiejohn
Old Feb 26, 2012 | 11:59 AM
Frankenvette's Avatar
Frankenvette
I have a T5 sitting in my garage but need to find the time to install. I got lucky and found an aftermarket Z-spec unit made for the mustang cobra. A couple of thoughts, find out what kind of T5 it is. If it came from a 4 or 6 cylinder not worth fixing. You should be able to find the tag or casting number on it and check against the internet. If it is from an 8 cylinder you then need to find out if it is a world class (wc) or older. The wc were in most cases upgraded units. From there the torque rating can be anywhere from 250 to around 310 ft-lbs continuous rating.
As far as upgrading, there are aftermarket parts for servicing the T5 including upgrading. Not sure of availability and cost where you are located and it could be cheaper to find a stronger unit if what you have turns out to be a low power unit or the service parts cost more than a quality used unit.
Old Feb 26, 2012 | 01:07 PM
RobRace10's Avatar
RobRace10
Here is a table on T5 trans. Ford started using WC versions in 85. The tag on the trans will say something like 1352-242 and that will tell you the torque rating based upon this chart.
Info on T-5's
http://www.moderndriveline.com/Techn...t5_history.htm
Old Feb 26, 2012 | 01:34 PM
Denpo's Avatar
Denpo
Originally Posted by thegavel
Gooday all,
is stripped.
installing it.
Gav
You can check my resto thread for some pics and details.
I bought a broken (3rd as always) WC T5 (from a Iroc-Z '91 camaro) and changed the internal myself. Namely a 3rd gear and a countershaft.
I put regular (USA/Mexico original tremec part, no chinese) gears, but choosed to buy the heavy duty case from G-Force.
From what I heard the main reason for T5 to fail is that the case is too thin and flex, spreading the gears apart.
Anyway, a broken T5 is probably a T5 than flexed its case, so you'd better change the it anyway.
Watch out, this case comes with the ford style mounting holes drilled, you'll have to get the GM style hole drilled yourself, and those must be precisely drilled, unless you Trany won't be correctly aligned.
My solution was to cut and resurface the front face of the old case and use it as template (still got it, can sale).
With those parts and a rebuild kit it costed roughly the price of a rebuilt one, but I know what's inside.
If you do the rebuilt, get a repair video, with it it's piece of cake, without it's impossible not to do something wrong.
When came the time to tune the endplay of both shaft, I got to admit my mechanic buddy help was invaluable to machine me the perfect sized shim.
It not the easiest way, but you get a quality rebuild for a good price.
All in all the whole swap costed me roughly 1500$, including a lakewood scattershield, short throw shifter and flywheel/clutch/pressure plate assy.
Old Feb 27, 2012 | 02:25 AM
thegavel's Avatar
thegavel
Thanx for the replies Guys,
Found it on feebay and he only lives around the corner from me.
From what he told me it's from a (Aussie) AU Ford Falcon.
I just sent him an email to find out what engine etc it was.
Hopefully he'll get back to me soon.
I'll let you know what I find out.
Thanks again.
Gav
Old Feb 27, 2012 | 03:33 AM
thegavel's Avatar
thegavel
Okay just got message from seller,
The car it came from was a 2000 AU XR6 ute
(my American friends wont know what the heck that is).
"13-52-065-908 TREMEC borgwarner automotive is all thats on the box"
Been doing some searching, only info I can find is that this box comes from
a "Ford 1984 Mustang/Capri 5.0 V8" so I'm guessing that Ford Australia
might have used this box too.
Cheers,
Gav
To Rebuilding a T5.
