power window problem
Old Feb 26, 2012 | 09:55 AM
nickscorvette's Avatar
nickscorvette
3rd Gear
Default power window problem
My drivers side power window does not work. Passenger side is ok. Are the left and right side fused seperately? Where is the fuse located on the fuse block?
Old Feb 26, 2012 | 10:05 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by nickscorvette
...My drivers side power window does not work. Passenger side is ok. Are the left and right side fused seperately?...
No.
...Where is the fuse located on the fuse block?...
Owner's manual will have a diagram of the fuse block.
Check driver's switch first. It usually fails first because it is used more often. Connect the driver's wiring harness to the passenger's switch and see what you get.
Old Feb 26, 2012 | 10:39 AM
nickscorvette
3rd Gear
I ckecked the drivers switch with a meter for contiuity in both up and down setting....continuity is good in both directions...any ideas?
Old Feb 26, 2012 | 10:47 AM
DC3's Avatar
DC3
When I had this problem it turned out to be a broken power wire near the door hinge. Just wear and tear over the years.
DC
Old Feb 26, 2012 | 11:02 AM
nickscorvette
3rd Gear
Thanks DC...I'll check it
Old Feb 27, 2012 | 09:07 AM
jdp6000's Avatar
jdp6000
Take the door panel off and see if you have power to the motor. Check for a broken wire as suggested. The other possibility is corrosion on the ground. the motor is grounded to the regular and the regulator is grounded to the door frame which has a black ground to it.
You can run a second ground to the motor from the battery to double check if the door ground is an issue.
Jim
Old Feb 27, 2012 | 09:17 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
My driver side motor burnt out.
The motor has a thermal switch in it so that when it is up or down and cannot go any further, the motor heats up and the thermal switch turns it off.
The replacement motors are not cheap and replacing it is an excuse to curse the name of everybody at GM for an afternoon.
To power window problem
