From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Hey Brad,
when you get the Hurst set up, would you mind sending me the info on part numbers, where you got it and what you paid for it ?
Looks like I may go that route as well.
It appears to me the part number is 3910028 for the actual shifter, not sure about the linkage, etc.
Thanks.
Thanks.
I found it by using the search categories they have on their site:
drivetrain/shifters/shifter-install kit combos/chevrolet/corvette/your year model.
I'm going to try and snag a used setup from a forum member or ebay because that's pricey to me but it would take out the guess work and you know you'll have a new, solid shifter.
Hey guy's I'm doing a 4 speed swap as we speak. the cross member out of an automatic will not work. I have an 82 vet with a 700r4. i had to buy a 80-81 cross member and the shifter bracket to make it fit. I bought a m-20 Muncie to put in the car since i have a 3.08 rear end.
i have about 1800.00 bucks in it total to do the swap. This includes all the parts i needed not including the time and labor.
I am doing the 4 speed swap as we speak and a full list of parts for the kit.
SOME PARTS ARE FOR 77 ONLY
1. 69 muncie trans. $600( online) with receipts from shop)
2. 621 bellhousing $125(swap meet)
3. pedal assembly and linkage to clutch for $175 shipped(from here)
4. flywheel 456N $10(back of blazer in junk yard) ($35 to resurface)
5. clutch fork $70 (ebay)
6. lower shift boot $25(ebay)
7. clutch 11inch $135 (NAPA) NAME BRAND LUK
8. hurst shifter 20$ swap meet ( clean and put back together 1 hr labor
9. hurst shifter install $145 (summit) part number 3738611 for late 60`s-- early 70`s
10. hurst shifter handle $72 hurst part number 538-7991 for 77-82 only
11. hurst back up light switch $25.(summit)part number 2480003
12. z bar bracket $14(zip corvettes)
13. z bar rebuild kit $34
GRAND TOTAL OF $1485.00
Just waiting on buddy to come and weld in bracket
Reason: wrong parts for certain years
With your 3.08 rear gear and an L48 engine you'll want to get a trans with at least a 3.XX first gear.An ideal start off first gear ratio close to 10.Find a transmission that would work well with that 3.08 rear gear or you won't be happy with the performance and end up changing rear gears to get the performance you want a 1K expense.Then when you change rear gears your rpm's will be much higher in 4th gear,no OD.I have the same combo and went with a Richmond 6spd with a 3.28 first gear.Take offs are quick and the gear spreads are just about perfect and with a 6th gear OD my hiway rpm's are around 2k @ 65mph.If your going thru all the work of installing a 4 speed may as well do an OD trans.Sucks doing the same job twice! More expense at first but will cost you less in the long run and you'll have more !! Aloha's
