Replace Oil Pressure Sending Unit
Old Feb 22, 2012 | 04:16 PM
oh1vette's Avatar
oh1vette
Default Replace Oil Pressure Sending Unit
OK, I know I over think all this (simple) stuff and internet searches just adds to it sometimes.
First off, price: MAM $64.99, Ecklers $39.99, Auto Zone $17.99. I'm not after a correct restoration so any reason why the $17.99 would not work?
Any trick or tips on replacing the oil pressure sending unit (switch) on a 77?
Saw on some post the need for a "special" socket, but it just looks like an open end wrench would work...am I missing something?
Also, anything on the threads or just screw in dry?
Appreciate it....
Old Feb 22, 2012 | 04:25 PM
TimAT's Avatar
TimAT
As long as the resistance and scale are correct in the new sender it makes no difference if it's $10 or $100.
I've seen new ones with a hard red or blue sealer applied come right out of the box. What you want it to ensure a good ground between the sender and the block or the gauge will read funny.
Old Feb 22, 2012 | 04:29 PM
Paul L's Avatar
Paul L
Just thread it in. A little blue Loctite would not hurt. NAPA is fine.
Old Feb 22, 2012 | 04:30 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
There's an oil LIGHT sending unit(not on Corvettes) that requires a special socket.
The bell shaped sending unit requires nothing special, toolwise.
Like Tim said, good ground is important. If no sealer on the new threads, ONE wrap of teflon tape is plenty.
Old Feb 22, 2012 | 04:44 PM
oh1vette's Avatar
oh1vette
Thanks alot guys.....
doesn't look like there is a ground wire on the unit - - 1 wire with a blade connector plugging into the sensor....
Old Feb 22, 2012 | 04:48 PM
KapsSA's Avatar
KapsSA
It's grounded to the block through the threads.
Old Feb 22, 2012 | 04:53 PM
oh1vette's Avatar
oh1vette
Gotcha....
Old Feb 22, 2012 | 05:14 PM
7T1vette's Avatar
7T1vette
That's why you don't want to put teflon tape on those threads...teflon is an insulator.
Old Feb 22, 2012 | 05:43 PM
John 65's Avatar
John 65
Go with the 17.00 Napa sender. Works just fine.
Old Feb 22, 2012 | 06:47 PM
oh1vette's Avatar
oh1vette
Thanks alot guys - - -
And 7T1 - I hear ya on the tape....
Old Feb 22, 2012 | 07:38 PM
Paul L's Avatar
Paul L
How do you like the C5?
Old Feb 23, 2012 | 11:29 AM
oh1vette's Avatar
oh1vette
O man I love the C5....obviously more of everything compared to the C3...
But I do like the C3 body lines.......
Haven't had the C3 on the road in 15 yrs....back when I bought the C5 it was either restore the C3 or buy the C5, so instant gratification led me to the C5.
Just starting back on the C3 now, but more of get it back on the road project ($) Vs a restoration($$$$)...
To Replace Oil Pressure Sending Unit
