windshield frame sealant
Old Feb 25, 2012 | 08:21 AM
oldgto's Avatar
oldgto
Default windshield frame sealant
We took everything off the windshield frame to weld in new corners, and patch some small holes. In the channel, along the top of the frame (under the T-top header trim) was a thick, black, tar like sealer. Can anybody tell me what, or where to find something to put back in there when we re-assemble it?
Old Feb 25, 2012 | 08:32 AM
vanice's Avatar
vanice
3m has a string like product comes in black. You will find it at any body and paint supplier. We use to use it on the assembly line back in the day. We use to call it dum dum go figure
Old Feb 25, 2012 | 08:35 AM
Andy1961's Avatar
Andy1961
6th Gear
I think you will need 3M 08578 sealant i could be wrong but i am sure there will be someone out there that would know for sure.
Andy
Old Feb 25, 2012 | 04:06 PM
Rich's'78's Avatar
Rich's'78
Default not that you asked ....
If you had holes in the top of the birdcage, carefully inspect the area below the base of the windshield area, under the FG 'wings'. There is often perforation rust there too and it is hard to see and hard to fix since access is almost impossible w/o removing the FG.
Old Feb 25, 2012 | 08:56 PM
oldgto's Avatar
oldgto
Thanks for the info! We did find some more holes down below, but only on the driver side, and some in the driver door bottom as well.
(And here I thought we were done with the welder!)
Old Feb 25, 2012 | 09:22 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Andy
Andy is correct, that is the right number for the strip caulk and you'll find this stuff is not as hard but will work just fine.
Willcox
Old Feb 26, 2012 | 05:07 PM
oldgto's Avatar
oldgto
Thanks! We`ll look for it. Today we got more of those holes exposed and got the grinder in there so we can get some new metal welded in next time we play!
To windshield frame sealant
