'81 Custom Intake
Old Mar 3, 2012 | 01:09 AM
texasbaehr's Avatar
texasbaehr
Default '81 Custom Intake
I replaced the top end of my 81 motor with an Edelbrock Performer EPS manifold, Performer 600 Carb, and HEI vacuum distributor. All the Emissions equip is gone. I replaced the staock Cat with a high flow Cat and installed DynoMax super Turbo mufllers.
I wanted to do something different with the intake and air cleaner set up so I designed and mocked up a custom airbox from foamboard to get all the clearances and fit correct.
I fabricated the airbox from FRP and used two Specter Cone filters and 22-1/2 deg tubes. Fit was perfect with 1.5" of clearance under the hood all the way around.
Car runs much stronger and more responsive then the stock setup.
Old Mar 3, 2012 | 08:05 AM
Mark Riles's Avatar
Mark Riles
Is there a reason for the long peninsula pointing forward to the fan shroud? Looks aside, does it have a function? Everything else looks good.
Old Mar 3, 2012 | 08:08 AM
PHPD7102's Avatar
PHPD7102
St. Jude Donor '14-'15-'16
After installing my ZZ4 crate motor with an edlebrock "Air Gap" intake I had air cleaner clearance issues on my 81. I ended up using Spectre Performance to build a custom system myself.
I almost did it like you did at first but I figured with the cleaners sitting right above the headers like that it would be doing nothing but sucking in hot air. I ended up with a single cone system at the front of the motor where the mechanical fan used to be. I run electrics now so that gave me some extra room to play with. I know even that isnt ideal but for now its the best I can figure out.
Old Mar 3, 2012 | 08:32 AM
qwank's Avatar
qwank
Nice, a "hot Air" intake.
I don't know, it looks kind of ghetto fabulous to me.
Old Mar 3, 2012 | 11:25 AM
texasbaehr's Avatar
texasbaehr
Just extended to cover the gap. I'm fabricating covers to go under the filters and fill in the rest of the gaps and also keep the heat from the intakes. This is a work in progress.
Old Mar 3, 2012 | 01:53 PM
Red 69's Avatar
Red 69
Can you provide more detail on what FRP is, where it is sold, and how the air box was formed? This is a material I am not familiar with and can't be alone in this regard. Even if someone doesn't care for your design, knowing how it was made can help someone fabricate a design of their own.
Old Mar 3, 2012 | 02:04 PM
JEST's Avatar
JEST
fibre-reinforced polymer
You have seen it many times. Most restaurants use it somewhere in the kitchen and/or restrooms. Usually white and textured.
Old Mar 3, 2012 | 02:09 PM
Mark Riles's Avatar
Mark Riles
Kind of looks like a nice looking engine underneath. Shame it's covered up. Black intake, black valve covers. I tend to like the stealth look.
Old Mar 3, 2012 | 03:34 PM
corvettejockey's Avatar
corvettejockey
I totally like it. Do you have any pics of how you made this. Something in a step by step pic process.
Old Mar 4, 2012 | 10:59 AM
texasbaehr's Avatar
texasbaehr
Fiber reinforced polymer. I bought 1/16" flat sheet stock at a local industrial supply store. The local home stores sell it in 4x8 Sheets but its textured and does not have the strength.
Parts are cut by scoring and breaking it or bandsawing for curves. Tack the parts together with hot glue then use fiberglass resin and cloth just like you would to repair/ replace body panels on a Vette.
Old Mar 4, 2012 | 12:37 PM
alswagg's Avatar
alswagg
I like it, How much would you charge to make another?? Very interested Al
Old Mar 4, 2012 | 08:33 PM
Tim81's Avatar
Tim81
I do like the way it looks, but I have to question if it functions any better then using a open element air filter with a drop base for hood clearance. Either way you are sucking in hot air from under the hood. Personally I run a open element and have not noticed any difference in the way the car runs. It does look nice....Tim
Old Mar 4, 2012 | 11:16 PM
texasbaehr's Avatar
texasbaehr
This has to be custom fit for your application. No way would this fit on any other vette, too many variables. I can send you my drawings if interested. If you've worked with fiberglass before then this would not be very difficult to fab.
Old Mar 4, 2012 | 11:23 PM
texasbaehr's Avatar
texasbaehr
This has a drop base also. The twin cone filters have more surface area than a standard 14" low profile filter. I am fabricating shields that will go under the filters and ducts under the hood to direct fresh air from in front of the radiator to the intakes. I doubt I will see much diff in perfomance since I'm only running about 250+/-HP. If you have a high performance engine and run it hard the cool air intake will make big difference in performance. On a stock motor you would never notice.
Old Mar 5, 2012 | 09:24 AM
alswagg's Avatar
alswagg
I would appreciat the drawings. I do work with fiberglass quite often, as I was an engineer for a Major boat builder for 9 years. Now, we have our own company. The air intake you built if very nice and should be respected as such. Thanks again Al
Old Jul 3, 2012 | 08:38 PM
corvettejockey
I PM'd you.
Old Jul 3, 2012 | 08:47 PM
thiatt's Avatar
thiatt
I like it, it has a night rider feel.
Old Jul 4, 2012 | 10:44 AM
79L48's Avatar
79L48
I like it, too. I agree for a moderate street engine that it is plent sufficient to have the cones where they are. It's a good custom look without being blingy. And, you did it yourself, which is totally cool.
To '81 Custom Intake
