Here is what I do and have not had a disaster that I know of.
I run Castrol 10W40 regular blend oil
And a bottle of Comp Cams break in additive. .
I change my oil 2Xs a year on what ever is in the garage.
I donot run synthetic, but im not saying I won't at sometime, but if I do, I would have no problems with "Royal Purple" or Amsol.
But im a big fan of anything Comp Cams.
Check the first post of the Sticky. Everything you need is there. No need to go through the 508 posts unless you want to educate yourself further on the why behind your choices.
There are 4 posts on this thread that have been rehashed over and over in the sticky that are just flat out wrong. Facts are modern SN/SN oil formulations even when combined with one of the dozens of "miricle" additives are not sufficiant or the correct approach for long term flat tappet cam protection for a variety of reasons. Read the first post in the sticky. It is a consolidation of information from the oil companies, cam companies, experts in many fields and input from hundreds of sources and writeups that has had hundreds of hours of research and effort put into it and is updated regularly as new information is available. Use it. No need to even go their in this thread.
How old is your engine? How many miles has it run with 'standard' oils being used?
There's your answer.
These engines are all over 30 years old years old. Many have run over 100,000 miles. If you buy a "standard" oil that contains the additive package in use when these were built you are fine. As late as 1988 the Standard oil was required to have over 1200 PPM Zinc. Now all are required to have under 800 with most testing well below so, . Run a "standard" oil for the year your car was built. The list of those oils are in post 1 of the sticky. Pretty simple.
