New Engine = New Transmission?
Check out Bowtie or find one locally and have a local shop go through it for you..
here is a 200 vs a 700
http://forums.corvetteforum.com/c3-t...-or-2004r.html
I just talked to Rich Weller last week about doing my trans...
Do a searh here 2004r vs 7004r
THis is what im thinking about getting ... I have to give him my order by friday, but im fighting with myself I Have so much $$$ in my car right now that adding another 2-3 k I Just dont know...
Transmission: 2004R Level 2 1 $1,195.00
Torque Converter: 2200 2004R Heavy Duty (C24HDT) 1 $175.00
Crossmember: 68-79 Corvette 1 $195.00
Shifter: 77-81 Corvette (SC2403) 1 $94.50
Inspection Cover: 2004R Universal(K35803U) 1 $25.00
Dipstick: 2004R Universal 1 $30.00
TV System: Quadrajet [1902/1903/1904/1905/1906] Throttle Bracket Single Non Braided 1 $139.95
TCC Wiring: TCC Relay Kit 1 $35.00
Transmission Lines: , $0.00
Speedometer Gears: New Set 2004R Drive/Driven Gears W/ Used Housing Drive Gear: 10 Driven Gear: 28 1 $70.55
Installation Tools Cost
Misc Items Cost
~ $ $0.00
Special Special - free torque converter to $ 175.00 value $-175.00
Free Tee shirt - need size $0.00
Sub Total $1,785.00
Tax $138.34
S&H $0.00
Total $1,923.34
Misc Items Cost
~ $ $0.00
Sub Total $1,785.00
Tax $138.34
S&H $0.00
Total $1,923.34
Transmission: 700R4 Level 2 1 $1,295.00
Torque Converter: 2200 700R4 Heavy Duty (C48HDT) 1 $175.00
Inspection Cover: 700R4 standard Tin (14038632) 1 $37.25
Dipstick: 700R4 Low Hood 1 $30.00
TV System: Holley 4100 Throttle Bracket Single Non Braided 1 $139.95
TCC Wiring: TCC Brake Switch Kit 1 $35.00
Speedometer Gears: New Set 40/45 Series Drive Gear: Driven Gear: 1 $75.95
Installers Kit(Pressure Gauge Temp Gauge Inline Filter) $69.95
Misc Items Cost
Crate fee $60.00
Free Torque Converter special $-175.00
Free tee shirt - need size $0.00
Sub Total $2,032.60
also if you do it yourself you will need the pressure gauges that they sell to start the warranty.. you have to call in the gauge readings before the the warranty can start.
here is a bunch more for ya
I have done a bunch of homework on this swap..
try this one... if not try the search feature 2004r vs 7004r
Isn't the whole reason for Bowtie Overdrive's existence to help people put the "wrong" transmission into their cars?
Have you taken any consideration of the gear ratio of your differential? Because the diff is really the difference. If your gear ratio is around the 2:70s/2:80s you will over work your engine, so find out what your gear ratio is. I bought a 3:54 ratio differential from Ikerds, because not only do I want to feel the HP but gas mileage as well, at 4th gear with the 700r4 it brings down the ratio to what my current ratio of my 2:72 diff is at in 3rd gear, which is pretty good on gas for a sports car. Things to think about. There are some good gear ratio math calculators on line. The 4th gear in a 700r4 is .72 and not 1 to 1 like the turbo 350 3rd gear. The engine runs cooler as well. yes you will have to cut the drive shaft, but you have to look at the big picture. If for some reason you needed work on your tranny in the future, parts are a lot easier to get and less expensive for a 700r4, because they are more common, so the price of cutting a drive shaft is just pennies as far as I am concerned.
I thought about this before I planned on throwing all kinds of dollars in my car, I just have a motor decision to make.
