Trans mount bolt size/thread
Old Mar 14, 2012 | 04:57 PM
SpinMonster's Avatar
SpinMonster
Default Trans mount bolt size/thread
Does anyone know the bolt thread that goes into the rubber part? I need to buy new ones for my new mount that didnt come with the bolts.
Old Mar 14, 2012 | 07:22 PM
C2C3PO's Avatar
C2C3PO
The original bolt you are referring to is a 5/8" bolt that has a 1" long shank (threaded portion) at SAE 14 pitch !
The bolt was installed with a thick lock washer and flat washer respectively.
Hope that helps.
Rick
Old Mar 14, 2012 | 09:34 PM
Steve2147's Avatar
Steve2147
That's a 7/16"-14 (5/8" head size).
Steve g
Old Mar 15, 2012 | 10:28 AM
mapman's Avatar
mapman
Frame crossmember to mount bolts per the parts fiche:
1963-67 was 7/16, 14 tpi, 1" length
1968-79 was 7/16, 14 tpi, 1 1/8" length
1980-82 was 7/16, 14 tpi, 1 1/4" length
Old Mar 15, 2012 | 10:35 AM
qwank's Avatar
qwank
since we're talking about bolt sizes, does any one know how long the 4 bolts are that hold the manual transmission to the bellhousing. I'm guessing they're also 7/16"-14, but need to know how long they are.
Old Mar 15, 2012 | 04:39 PM
Alan 71's Avatar
Alan 71
Hi q,
On my 71 the transmission to bell housing bolts are 1/2"-13 x 1 3/4", with a flat washer.
Regards,
Alan
Old Mar 15, 2012 | 06:16 PM
mapman's Avatar
mapman
2nd edit: as noted by Alan 71 above, the parts book shows the bolts as 1/2 - 13 tpi x 1 3/4".
edit: I miss read your post, the bolt size below is for the bolts attaching the transmission to the transmission mount.
I you are talking about your 1981, then the parts book shows the bolts as: M10 x 1.5 x 35
To Trans mount bolt size/thread
