C3 half shafts
Old Mar 15, 2012 | 05:17 PM
haydengm1's Avatar
haydengm1
Default C3 half shafts
I have a 75 with a 468 cu in alum head, hyd roller with about 550-575 hp.
I am looking for anyone that has experience with aftermarket half shafts that can withstand higher horsepower motors.
I appreciate any words of wisdom.
Thanks, Gary
Old Mar 15, 2012 | 05:54 PM
Gordonm's Avatar
Gordonm
I have had a set of these in my car for a few years. I think they say up to around 750 HP with these. Reasonably priced also.
http://www.fortwayneclutch.com/index...es.html?cat=28
Old Mar 15, 2012 | 09:29 PM
Hadez's Avatar
Hadez
Be sure to get the spicer u-joints without the zerk (grease) fitting. They are stronger and probably a weaker link in the drivetrain than stock half shafts themselves.
Old Mar 16, 2012 | 07:53 AM
haydengm1's Avatar
haydengm1
Thanks for the information.
Old Mar 16, 2012 | 11:04 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Depending on what you'll be doing with that much power, you could well be in the market for an HD diff, if not a full 12-bolt IRS conversion, as well as other bits such as HD stubs and 1/2" lugs, as I've learned the hard way you don't have to be on slicks to break a 10-bolt and other stuff back there. My $.02
Old Mar 16, 2012 | 11:50 AM
FlyLS6's Avatar
FlyLS6
Default Half Shafts
What did the L88 cars come equipped with a standard equipment? And how did they hold up. I don't know that they made as much power as the OP's car, but most considered them on the high side of 500 didn't they?
Old Mar 16, 2012 | 09:36 PM
gcusmano74's Avatar
gcusmano74
Remember one more thing. Back in the day, the street tires did not have anywhere near the grip of today's tires. That acted as a "safety valve" to protect the drivetrain. The tires would spin, limiting severe loads on the drivetrain.
Old Mar 16, 2012 | 10:06 PM
7t9l82's Avatar
7t9l82
"back in the day" we had slicks. there were a few L-88 cars drag raced. the stock rears held up but you could hurt something too.
Old Mar 16, 2012 | 11:26 PM
spdrcr29's Avatar
spdrcr29
You should check out www.dennysdriveshaft.com. Bought mine from them. They work great and look awesome. They have everything from half-shafts for the vettes, driveshafts, u-joints, and much more...
http://www.dennysdriveshaft.com/c34_...lf_shafts.html
Old Mar 18, 2012 | 01:58 AM
Gale Banks 80''s Avatar
Gale Banks 80'
L-88's came with all the standard parts of a Big Block car. Nothing diffrent in this department.
Old Mar 18, 2012 | 02:27 AM
73-84 IMSA Widebody's Avatar
73-84 IMSA Widebody
floaters
To C3 half shafts
