points eliminator kits?
Old Mar 16, 2012 | 04:04 PM
MAC 72's Avatar
MAC 72
Cruising
Default points eliminator kits?
Hello all! I have been looking at this forum for a few days now and really like what I see and hear, so I have decided to join. I have a question that may have been asked already, but I haven't seen it. What do you guys think about the points eliminator kits? Has anyone installed them?
Old Mar 16, 2012 | 04:21 PM
Mashman's Avatar
Mashman
Lots have.
There are a number of kits, most use Pertronix.
I have a breakerless-se (http://www.lectriclimited.com/breakerless_se.htm), havn't had any problems with is at all.
MelWff's Avatar
MelWff
I've used the Mallory Unilite on 2 different cars for multiple decades without issues. Other people like the Pertronix II.
Old Mar 16, 2012 | 04:23 PM
Peterbuilt's Avatar
Peterbuilt
Default Welcome!
Points or not will surely start a lively debate.
I started with points, read a few ads about how wonderful points eliminators were, got brainwashed, and tried them (Pertronix).
No difference, not more HP, no better mileage and some indicated that if the eliminator failed it meant a tow home and a wait for a replacement.
I went back to points.
My 2 cents worth.
Regards Pete.
Old Mar 16, 2012 | 06:31 PM
birdsmith's Avatar
birdsmith
I went with a Pertronix about 12 years ago. Works as advertised. Looks stock w/exception of one additional wire and has been absolutely trouble free.
Old Mar 16, 2012 | 06:45 PM
oldalaskaman's Avatar
oldalaskaman
best thing since hot buttered popcorn, doesnt do anything for hp , but does increase reliability. BTW an HEI from a pre computer car fits perfect and only requires one wire to hook up, if you want to save your oe dist.
Old Mar 16, 2012 | 06:58 PM
Les's Avatar
Les
I ran a Hayes points eliminator kit on my 69 for around 20 years and just upgraded to an Accel 300+ ignition box. The trigger in the distributor from the Hayes kit is still being used by the Accel box and it's all been flawless since day one. My new system, and most other modern ones, have a rev limiter built in and that's real nice to have if you ever run the car hard. I grew up having to adjust points and timing on a regular basis to maintain top performance and I don't miss doing that at all.
Old Mar 16, 2012 | 07:59 PM
Solid LT1's Avatar
Solid LT1
Hook up any other kit besides a Pertronix Ignitor II or III wrong and you will fry them (including the Ignitor I.) Ignitor II or III will also not fry if you leave keyswitch in run position, most others will. Throw an Ignitor on a worn out old disstributor with a broken ground wire to the points mounting plate, and it won't perform very well. Take the time to bring the distributor back into decent condition and it will run well for many years.
Do a cylinder balance test with the coil wire pulled out of the coil and have the high energy spark jump out of the coil tower to the 12VDC negative terminal and you can kill any trigger system where points would survive. Just thought I would put a little rubbing in there to my buddy, he knows who I'm talking about......
Old Mar 16, 2012 | 09:02 PM
flaco1801's Avatar
flaco1801
Buy an HEI with cable adapter, they are cheap nowadays...no more points, no hassles....they used to be 450 bucks..
Old Mar 16, 2012 | 10:11 PM
oldalaskaman
they are $140 on rock auto, no adapter needed. heres a moroso
http://www.ebay.com/itm/SBC-BBC-350-...99e725&vxp=mtr
Old Mar 16, 2012 | 10:31 PM
73sbvert's Avatar
73sbvert
Crackin' on...
St. Jude Donor '09
I had a Mallory (previous owner installed) and it worked great!
Have since upgraded to Mallory HEI however. Hasn't been started yet, so I can't tell you how it's working!
Old Mar 16, 2012 | 10:42 PM
oldalaskaman
put them in , set the timing, and pretty much forget about them , they just work
Old Mar 17, 2012 | 08:43 AM
BarryK's Avatar
BarryK
electronic conversion kits do absolutely NOTHING but cause you to spend money.
NO increase in power
NO increase in gas milage
LESS overall reliability than points
NO local parts availability so if the module fails you are stuck on the side of the road until you get a new module or re-install points
BUT what you did gain was the appreciation of the vendor you spent your money at buying the useless thing and on a somewhat positive note you will save yourself approx 5-10 minutes a year no longer having to check your dwell like you should do once a year on your points.
If you feel that saving 5-10 minutes a year of your time is worth the cost of the electronic conversion kit and are willing to live with a less reliable ignition system than by all means buy one.
If you insist on eliminating your points ignition than at the very least step up to a tach-drive HEI distributor and forget about those electronic conversion kits that otherwise do nothing for you.
Old Mar 17, 2012 | 09:33 AM
drwet's Avatar
drwet
I had one of the original Mallory Unilite systems years ago and got about 3 years out of it before it failed. I suspect the later units are more reliable based on the experience of others on this forum.
I put a Pertonix 1 in my '66 and its been there for years. The only advantage is I don't mess with points any more. I always hated them, I can't help but agree with the guys who worry about the reliability. If points give you trouble on the road, you have a chance of getting things working again. If your electronic setup fails, you have a bigger problem.
I guess it depends on which set of problems you would rather have.
Old Mar 17, 2012 | 09:48 AM
Mike Ward's Avatar
Mike Ward
I question those that infer that points are 'not reliable'. Perhaps they mean 'not durable' which is a very different parameter.
Points need a once a year adjustment in dwell, or maybe once in 3-4 year replacement for the average occasionally driven car. If ignored, performance will degrade slowly until such time that the car will not start or will run very poorly. The breakerless kits on the other hand fail suddenly and usually completely, albeit this is now rare on the latest units.
Since there is NO performance advantage, I'll stick with points and simply check the dwell once a year.
Old Mar 17, 2012 | 12:35 PM
tfi racing's Avatar
tfi racing
Three new sets of points,three failures within several miles,the last set simply fell apart.If you can find a decent set anywhere,sure they may be reliable...I put in the Pertronix and haven't been stuck yet.
Old Mar 17, 2012 | 01:08 PM
toddalin's Avatar
toddalin
I use the best of both worlds, the Mallory HyFire IV.
We run points, but they only act as a switch to trigger the ignition box that sets the duration. The duration is a function of the box (~45 degrees) and has little to do when the actual duration opening and closing of the points. Also, because the points only act as a switch, they don't arc and burn.
If the box ever fails, a jumper plug by-passes it in under a minute. The points can go so far out of adjustment that the car won't start or run on them, but plug in the box and all is good again.
While many will tell you that a set of good points can make as much power as a good electronic ignition, that is only true when the points are in good condition and properly set. Once they start to burn and go out of adjustment, that all changes.
To points eliminator kits?
Old Mar 17, 2012 | 02:17 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
I put that same Hayes system in my '69 in 1974. Ran fine for about 9 years, then started to break up under high throttle load (I suspect the switching transistor). Contrary to urban myth regarding electronic ignitions, it did not suddenly die. It just got progressively worse under load. I took the unit apart intending to fix it, but the internals were all potted up and it was next to impossible to get at the circuitry. Next option: I noticed on an oscilloscope that the Hayes VR sensor in the distributor put out a signal almost identical to the waveform in production HEI distributors. I hooked up a spare HEI module to the distributor, and it worked great, and has been flawless in my '69 since 1983. In the slim event that it would fail, any auto store or junkyard has replacement modules available, dirt cheap.
Old Mar 17, 2012 | 02:38 PM
Mike Ward's Avatar
Mike Ward
Mine most certainly died with no warning, no different than if I'd turned the key off. Being in the middle of nowhere on a nasty day made for a memorable experience. I understand that the gradual deterioration that you experienced may possibly more typical.
Old Mar 17, 2012 | 03:25 PM
mark6669's Avatar
mark6669
I have installed many pertronics kits for customers who think you have to electronic ignition for performance and relablity but I have points in my personal cars never any problems in 36 years of driving corvettes.
Mark
