Vac line identificatio
Old Mar 23, 2012 | 12:32 PM
85camarocrazee's Avatar
85camarocrazee
Default Vac line identificatio
78 l48. I can't seem to figure where these 3 lines go. They run up the drivers side towards the headlights but don't reach that far. The headlight vac lines are also run that route but are connected. One of the loose lines has a t fitting with 4 to 6 inches of line on each end. The second line is a quarter inch line with a yellow pinch style clamp and the last line is a bit shorter but has what appears to be a label indicating breather on it. All of the lines are just black with no coloring on them and originate below the washer fluid bottle....
Old Mar 23, 2012 | 02:44 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The assembly instruction manual (AIM) shows all the vacuum lines, their color codes, how they route, and where they connect. Do you have the AIM?
Post a pic of what you've found. Sounds like a PO has plugged some of the vacuum lines.
Old Mar 23, 2012 | 05:50 PM
Alan 71's Avatar
Alan 71
Hi 85cc,
I'm not sure where the washer fluid bottle is on your 78, but is it possible that these lines started at the vapor canister in the well behind the front wheel apron?
If so they should be connected various places on the engine.
Regards,
Alan
Old Mar 23, 2012 | 08:12 PM
LongIsland C3's Avatar
LongIsland C3
Ran into the same situation on my 80. Three lines, traced them back to the vapor canister which was no longer in use.
Old Mar 24, 2012 | 09:43 AM
85camarocrazee
yep they smelled heavily of gas fumes and the canister Im referring to is inside the drivers side fender well between the front wheel and the firewall. They definitely look like engine hoses but wasnt sure. I do have a vac line diagram I found while doing a search trying to "check" the headlight system to make sure it was good to go. The lines didnt come up however on the diagram I found... You guys have nailed it and thank you!! Now to get this thing together!! Bought it as a basket case literally, and almost 1 year ago already. JUst havent had the time lol....
Old Mar 24, 2012 | 11:26 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by 85camarocrazee
...The lines didnt come up however on the diagram I found...
That's because they are part of the emissions system and not the headlight vacuum system.
Old Mar 24, 2012 | 01:23 PM
BKarol's Avatar
BKarol
In 78 the can should look like this:
Old Mar 24, 2012 | 02:56 PM
CQRT's Avatar
CQRT
this illustration might help too :
http://www.ecklerscorvette.com/asset...ette/A8927.pdf
Old Mar 24, 2012 | 10:55 PM
85camarocrazee
That is the can and you are all Awesome!! Thanks again. Cleaned up some wiring and mounted some loose grounds more solidly. Cant wait to get this beast on the road!! Motor and trans are still in my Camaro while I get some things cleaned up and the fresh paint on her before she gets her heart...... But now its movie time with the wife lol after putting in some time in the shop.
To Vac line identificatio
