I was finishing up washing the Vert....getting the dust and grime off so I can begin getting it ready for the show season (polish, wax & detail, etc) when I look over and see my Toro leaf blower hanging in the tool house. So I thought "Why not?" So I did and it worked perfectly especially doing the wheels, blowing water from behind the emblems, and getting the water out from all those pesky places you can reach with a towel. AND it was fast!!
Now I know that it sounds silly and may look silly to use a leaf blower on your car to dry it. But I do have one question...will it hurt the car? I thought about the possibility of dust/dirt getting kick up and the air is it not being filtered air but I figure after washing the car, the concrete is still wet and the dirt/dust is pretty much washed away. Any thoughts?
You should be fine, as people have been using leaf blowers on cars for years. Very popular with bikers. Maybe not a bad idea, pulling the tube and washing the inside once in awhile.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I use my electric blower on my 70 the few times I have washed it. Like you say it helps get the water out of the places that would normally cause a drip down the side of the car. I would probably avoid using a gas blower on the vette. The reason I say that is because my gas blowers exhaust comes out the same tube the blown air does. Don't really want two stroke exhaust and oil on my good paint.
I've heard of alot of detailing guys doing this. There are special made machines also a person can use. Check out some of the detailing sites/sections. I just have a gas blower and have never tried it. I wonder how air nozzle would work?
As long as no debris enters or, more importantly, exits the blower , it should work fine. Maybe a small electric leaf blower, used just for that purpose would be better than the 'yard' blower.
I've used both a leaf blower and an air nozzle from my compressor. The blower works great on large areas. The nozzle is best for more detailed stuff.
If you use the nozzle, set your pressure regulator to about 50 psi. That's more than enough to move the water. You don't want to blow water into electrical connectors and such.
Never really knew this about two stroke leaf blowers mixing the smelly exaust into the air stream, as never owned one. Good enough reason for me not wanting to. I have a handheld household Hoover Porta Power vac, with provisions for plugging the hose into the rear outlet. I sometimes use this for blowing out the cracks.
From: Graceland in a Not Correctly Restored Stingray
I like using an air nozzle myself, but you do have to pay attention not to get too close if you don't have a soft tip tho (BTDT), and I suspect I get as many odd stares with the nozzle as one might with the blower.
While we're on the topic, I've also found filtering the rinse water significantly reduces the chances of spotting. The inline type for RV potable water work great.
My shopvac is the design that allows the motor to un-clip from the tank and be used as a blower. Works great. It is a bit easier to direct the flexible hose than the long tube on the leaf blower.
hot water is good for rinsing, it doesn't spot as much due to less minerals they are seperated out as part of the heating process. it also evaporates quicker
2016 C2 of Year
2015 C3 of Year Finalist
I've been using my backpack leaf blower for years. They work great with no issues. Before that I usually sheet the water off with an open hose nozzle. Finish with a waffle weave microfiber towel if there's any water left on the car
