Tranny Upgrade 75
Old Mar 24, 2012 | 04:15 PM
fxe82's Avatar
fxe82
Default Tranny Upgrade 75
I'd like to try and swap out the stock 3 spd auto tranny on my 75 to a 5 spd auto to help on the gas mileage. Any ideas?
Old Mar 24, 2012 | 05:04 PM
Mark Riles's Avatar
Mark Riles
This has been done and documented a lot. Not trying to be snobby but doing an advanced search and reading through a few dozen threads is your best first step. Then take what you have learned, find out what you are still not clear on, and then ask your questions. At this stage, where you obviously haven't outlined some very important things, there is just no way we can properly help you.
Old Mar 24, 2012 | 05:32 PM
aussiejohn's Avatar
aussiejohn
G'day,
Many people here have fitted a four speed auto such as a TH700 or a TH2004R, but I've never heard of anyone fitting a five speed. Have you found a likely 5-speed and from which donor car did it come? Others here would be interested if there is such a transmission readily available.
Regards from Down Under.
aussiejohn
Old Mar 24, 2012 | 05:48 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
If you go 200 r4 it is a fairly easy swap. You get a little lower 1st gear and overdrive. Bowtie overdrives can hook you up with everything you need for about $1500
To Tranny Upgrade 75
