Replacing front Ball Joints
2) Remove shock absorber
3) Place a jack under the end of one lower control arm
4) Remove the cotter pin from the lower balljoint attach nut and loosen the nut 1 1/2-2 turns
5)Position the jack pad so it is just barely touching the end of the control arm under the balljoint
6) Break the interference loose on the balljoint by separating it with a 'pickle fork' and sledgehammer.
7) With the end of the control arm firmly supported now by the jack, unscrew the balljoint attach nut the rest of the way.
8) SLOWLY lower the jack, allowing the lower control arm to swing down and out of the way while the spring extends and falls out of its pocket.
9) Unbolt and remove lower control arm, put it in a vise, and replace the balljoint.
10) Reassemble in reverse order. Unless you're incredibly strong and/or persistent you will likely need a spring compressor to get the spring back in.
11) Repeat procedure for opposite side.
12) Enjoy favorite beverage...
...You could concievably support the car with stands under the control arms, but it's really not very safe. If the car falls on you you will probably die. better to get the arms off of the car and change the balljoints on the workbench. Unless they've already been replaced they are riveted on with big hairy steel rivets that have to be drilled out. Much better to have them clamped into a vise for drilling...
I'm with birdsmith up to a point.
Skip step two.... it is just added work
Use # 5 to replace step 3 Only have the jack about a 1/4 inch below the A-arm
Skip the part in # 8 about removing the spring..... It is just added work
Skip # 9 why remove the lower A-arm? It is just added work
The lower ball joints are a bolt on. The uppers are rivets if they have never been replaced. Just grind the rivets of and punch them out with a hammer and punch
I just sit on my carpet
Just grind the rivets off and punch them out with a hammer and punch
Regardless of the method I use I always err on the side of caution.
I chain the spring to either the lower control arm, chassis, or upper control arm until the compression has been released.
IF something slips in just the wrong way.... your head, the fender, the ceiling, and the roof, won't stop the spring depending on how much compression is left, and which direction it flys or bounces.
You can do it safely, but be careful!
Regards,
Alan
Regards,
Alan
Completely agree. I just did the job about a month ago. Before I lowered the jack to release spring tension I threw a chain through the spring and then around the lower A arm with enough slack to let the A arm all the way down but not so much that it wouldn't catch the spring if it came flying out. Fiberglass work sucks much worse than suspension work... dental and cranial work sucks even worse than that...
If you are doing both pop the lower ball joit first
Thanks.
Way back in the 80's I bought 550# front spring and was told to get a spring compressor. Even being young and dumber and never seen a spring change done before. I thought what a wasted effort. I returned it un used. After years of working in the shop this forum was the first time I ever even heard of unbolting the lower A-arm. I get paid to change springs. Sometimes when the car has only done a couple of laps we change springs in the hot pits and we have the car back out in a very short time.
Discussions on the internet is kind of like the special olympics, your still special!
I've done hundreds over the years and still use a compressor on the long ones. Only takes about 3 minutes per side.
You can't blame anyone for being too safe with something they have never done before.
Questioning why the lower control arm must be lowered. If the weight of the car is being held up by jackstands under the LCAs the spring isn't going anywhere. Can the upper BJ be popped and the UCA raised out of the way to allow the LBJ to be popped and hub moved to the side to facilitate replacement of both BJs?
Still trying to determine what brand I should use for replacement. Having no luck with the Muskegon Brake site, any other sources for XRF? Local shops are recommending the NAPA premium ones. They any good?
You know we worry about you because we care.
I'm lucky to still have my right hand. It was thoroughly crushed.
