Wiper door question
Old Apr 4, 2012 | 12:52 AM
Markhudson's Avatar
Markhudson
Default Wiper door question
I see in the schematic that there is supposed to be a Wiper door vacuum relay or actuator that opens a wiper door but i dont know where that is on my 82. What and where is the wiper door? Im trying to troubleshoot why my headlights arent going up and down and this means making sure all the hoses and relays are there and working but i dont see the wiper door or the relay that is supposed to be on the firewall in the engine compartment...anyone got a pic so i know what im looking for? thanks everyone
Old Apr 4, 2012 | 01:54 AM
wombvette's Avatar
wombvette
No wiper door on an 82.
Old Apr 4, 2012 | 07:54 AM
Roco71's Avatar
Roco71
Well that's one less thing to worry about.
Old Apr 4, 2012 | 08:39 AM
Sully1882's Avatar
Sully1882
wiper door was only present in 68-72 and then was eliminated in 73 with the long hood.
Sully
Old Apr 5, 2012 | 10:33 AM
rponfick's Avatar
rponfick
Best decision GM ever made was to get rid of the wiper door in '73. I just finished tuning mine for the upteenth time on my '69 (hey, I just made a rhyme). Now, everything works properly, except door tends to creep open after I shut the car down. I've chosen to look at it as a custom engine cooling feature.
Ralph.
Old Apr 5, 2012 | 10:42 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...Im trying to troubleshoot why my headlights arent going up and down and this means making sure all the hoses and relays are there and working...
You're probably looking at the wrong (68-72) vacuum system troubleshooting diagram. You want 73-82.
Old Apr 5, 2012 | 02:51 PM
Markhudson's Avatar
Markhudson
You were right! I found the right one on the internet I appreciate yalls help!
Old Apr 5, 2012 | 03:10 PM
Roco71's Avatar
Roco71
see if this helps http://forums.corvetteforum.com/c3-t...tem-works.html
Old Apr 5, 2012 | 03:12 PM
Markhudson's Avatar
Markhudson
yes that helps alot thanks! I appreciate it
Old Jun 1, 2012 | 03:54 AM
tristan69's Avatar
tristan69
Ralph.
Ralph, did you ever figure out why your wiper door raises slowly as mine does the same about a minute after I shut the car off?
Old Jun 1, 2012 | 08:51 AM
rponfick's Avatar
rponfick
Tristan, I thought I was the only one with this odd issue. No, I haven't worked on it yet, and it doesn't bother me much anymore. I will play with it one of these days.
Let me know if you discover anything.
Ralph
Old Jun 1, 2012 | 10:43 AM
7T1vette's Avatar
7T1vette
Lots of folks have that same problem. Most likely due to some wear/interal leakage on some parts with internal seals. I believe, it is caused when one side of the vacuum system leaks off faster than the other when the engine is turned off. If your vacuum system is very tight, I don't think that can happen. With a bit of wear (no defective parts), you get some 'wiper door creep'.
To Wiper door question
