Summit K1104 cam too much for 882 heads?
guessing yours is dish piston L48 ... and ... you're on a budget ... if both true ...
use summit K1103 camlifter kit
use thin shim head gaskets
replace valve springs, stem seals and pushrods ... but NOT w/ racing stuff.
All the poor guy wants is a cam to put in the engine, not the encyclopedia of static compression verses quench of the cylinder verses the DCR calculator.
If you can't put in a cam with at least 470 lift in a 350 and it pick up horses and feel good to drive to the driver then the engine is ready for a rebuild and not a professor's course in compression ratio in book theory.
The engine is not going to live on a dyno to ever to know the day compression drops from a stretched timing chain anyway!
But why expect anything less than a jumbled up mess that leaves the builder wondering if the lawn needs mowed instead?
well said ... and so true ... happens here again & again ... almost makes a body wonder if the usual diatribe is more about showing off some tech stuff they may've (or not) mastered ... than helping
The Lunati 10001K is identical to Summit K1103. Does it make any difference which one I get?
Should I upgrade stock springs with Summit set 174001 ($64) ?
Should I upgrade stock converter with G2699 (1,700-2,100 Stall) for $90 ?
I am on a budget for my 1977 because rest of the money is going for my 1963 Nova which is getting an LS 5.3 which came out of 2011 Truck!
It probably doesnt make a lot of difference which one you pick though.
The performance will be pretty similar, if not identical.
Matching springs would be a very good idea.
Since your on a budget, look here - http://www.jegs.com/i/JEGS+Performan...60402/10002/-1
Lunait comes with a cool sticker for the tool box!
Here is a write up on the cam from another forum.
http://www.hotrodders.com/forum/luna...on-196960.html
There is no "magic" to an engine, it obeys the laws of physics just like anything else, and a little knowledge about those laws can go a long way toward making smart choices in combining different engine components. In a nutshell, you can work harder, or you can work smarter. Another way of putting it might be like this: If you want a suit that fits nice, you can go to a suit store and try on suits all day, till you find one that fits nice, or you can have a guy take your measurements and bring you a suit that will fit, and get out of there and enjoy the rest of the day. If that's "overthinking", then I guess I'm an overthinker.
My advice to Waid is the more you know about what makes a car go fast, the easier it is to make it go faster, for less money, and, in the long run, spend less time doing it. Even if all you want is for the car to go "rumpety-rumpety" at the stoplight, knowing a little something about what makes a car go "rumpety-rumpety" will make it easier to do. Tim does have a point, though, it ain't rocket surgery, it's just an engine. Suck, squeeze, bang, blow, right? On the other hand, ya gotta have the right amount of suck, with the right amount of squeeze, with the right amount of blow, to get the most bang.
Keep the shiny side up!
Scott
Similar for pushrods ... with lotsa use they tend to begin fracturing around oil holes. jegs has nice set/16 pushrods from sealed power ( RP5000RK ) for under $25. Stock flat tappet sbc pushrods are 5/16" OD x about 7.8" long +/- 0.020"
stock converter AOK w/ K1103 cam in a 350.
g'luck
What is the difference between Sealed Power SLP-VS-739R & Summit Racing SUM-174001 ?
fill in approximate geographic location on your profile
stock OE retainers AOK with any spring I suggested ... you may need to ditch the oil splash cup but reuse OE retainer.
use both these valve stem seals:
seal replacement O-Ring: Sealed Power p/n MV-1233C (box of 16).
seal addition slip-on Umbrella: Sealed Power p/n MV-1598C (box of 16).
use an oring and an umbrella
Gearing, trans, horsepower expectations, intended use, compression, head capabilities, bottom end capabilities are all important considerations. But a DCR calculation is a really great tool to see if your in the ballpark or out to lunch especially when deciding on a compression ratio for a given cam or a cam for an existing compression ratio. My thought on building an engine from scratch or planning upgrades is to take all the above into account for all the parts selected from intake to oil pan. Well matched components throughout the build compliment each other. An otherwise well matched combination that is undercammed or over cammed, under carburated or over carburated ECT. will be detrimental to optimal performance.
