E brake cable
Old Apr 4, 2012 | 11:21 PM
TOM B1's Avatar
TOM B1
Default E brake cable
On my 69 E brake cable,Where the cable goes through the floor.
What protects the floor from the cable. The cable is cutting a slot in the floor..something must go in that hole.
Thanks;
Tom
Old Apr 4, 2012 | 11:49 PM
bluthundr's Avatar
bluthundr
It looks like it just hits the pulley and goes under - http://www.vetteweb.com/tech/vemp_04...e/viewall.html
Old Apr 5, 2012 | 08:36 AM
Alan 71's Avatar
Alan 71
Hi Tom,
My 71 has a small, round, black rubber grommet in the hole in the underbody that the cable passes through.
Regards,
Alan
Old Apr 5, 2012 | 12:17 PM
bluthundr's Avatar
bluthundr
Hmm, well a rubber grommet isn't going to keep the cable from chewing a hole in the floor. I would say something is worn out or out of alignment.
Old Apr 5, 2012 | 03:15 PM
Alan 71's Avatar
Alan 71
Hi,
I guess it all depends on the angle the cable is at when it goes through the underbody.
On my 71 with the original e-handle mechanism, cable, pulley, and pulley bolt, there doesn't appear to have been any wear in the grommet.
I think the hole in the mounting bracket that the cable passes through helps keep it from wearing on the fiberglass and grommet too.
Regards,
Alan
Old Apr 5, 2012 | 10:42 PM
TOM B1's Avatar
TOM B1
Ok I see, I will check the mounting, something must be bent or broken.
To E brake cable
