79 350 ballancer
Old Apr 7, 2012 | 11:02 PM
79c3man's Avatar
79c3man
Default 79 350 ballancer
ok I found out why engine in my vette wouldn't time right ,TDC is 12 degrees on timing tab ,either the timing chain is off ,or the ballancer has slipped or is incorrect ,can someone with a 79 corvette 350 tell me what ballancer diameter it should have and what timing tab should it have thanks
Old Apr 7, 2012 | 11:08 PM
7t9l82's Avatar
7t9l82
the L-82 takes an 8 inch balanced. i think the base engine is 6 . measure what you have.
Old Apr 7, 2012 | 11:24 PM
TimAT's Avatar
TimAT
See where the keyway is in relation to the TDC mark. GM changed them somewhere. One the mark and the keyway are nearly lined up and the other one is 10-15* off. Easy to correct- bolt on tab.
Old Apr 8, 2012 | 08:21 AM
jackson's Avatar
jackson
more than one change in timing index
very late models' TDC mark is offset from keyway about 40*
Old Apr 8, 2012 | 08:33 AM
Tim H's Avatar
Tim H
Your balancer and timing cover are mismatched.
Old Apr 8, 2012 | 09:27 AM
jackson's Avatar
jackson
Tim:
No ... Not late model C3 ... look at some later trucks etc ... have a metal "tube" spot welded near center of timing cover ... with crowded bay, you down look thru it to see mark ... those have the 40* split ... I mention it to help prevent someone from mistakenly accepting its damper for another vehicle.
perhaps mid-90's C4 has similar??? I dunno???
Old Apr 8, 2012 | 10:48 AM
Tim H's Avatar
Tim H
Originally Posted by jackson
Tim:
Well then I suggest you replace the dampner, timing cover, timing chain, and crank, because something ain't right.
Old Apr 8, 2012 | 01:09 PM
TimAT's Avatar
TimAT
Point is, there are several different combinations of timing marks, front covers, timing tabs and balancers. Over the years it's all become scrambled up and very easy to mix and match and have the timing marks appear in all sorts of odd places.
Old Apr 8, 2012 | 02:11 PM
jackson's Avatar
jackson
Tim:
I know you're mean well when you might suggest a slipped outer ring or a mismatched damper & tab, etc etc ... but
There are later GM & Chevy vehicles that have about 40* split at damper ... if someone were to try to use that damper with a typical C3 timing tab, it would never align right ... while it would align if used om intended app.
I've seen them on trucks ... by the same token, if someone tried to use a C3 damper on such a truck it also would never align right.
Old Apr 8, 2012 | 05:47 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
On early dampers through about 1969, the TDC mark on the damper is aligned with the keyway. Afterwards, the TDC mark on the damper is 10 degrees counter-clockwise from the keyway.
Old Apr 10, 2012 | 01:15 PM
79c3man's Avatar
79c3man
maybe I should start over, balancer is 6 3/4 ,timing tab is one of those aluminum ones mounted at about 2 oclock on timing cover, haven't checked the keyway in relation to the TDC mark yet
Old Apr 10, 2012 | 01:46 PM
drwet's Avatar
drwet
Why don't you buy yourself a timing tape for the balancer, establish exactly where TDC is and install the tape? I would also mark the damper in some way so you will know if the outer ring is rotating on the hub just in case that is the source of your problem.
Old Apr 10, 2012 | 05:02 PM
79c3man's Avatar
79c3man
I have a aluminum balancer cover on the balancer , TDC on the cover lined up with the balancer TDC ,and when we located tdc( by placing a coat hanger in no. 1 cylinder) it is 12 on balancer soooo, I was wondering if the 6 3/4 balancer is correct for a 79 350 non L-82 ,or if balancer is slipping or has slipped what is a good way to tell, then what is a good fluid balancer to go with ,resonably priced
Old Apr 10, 2012 | 08:44 PM
maxmachz's Avatar
maxmachz
I have the same dillemma on my '81. Connected the light to #1, un plugged the dist 4 wire plug to put in base timing mode, fire it up and no mark anywhere. Put the light on #2 and there is the mark, over to the passenger side. Watch it move as I turn the dist, timed it by ear, runs great....but if the balancer is slipped it would be nice to know, so I could replace it and not have a mess when it lets go.
To 79 350 ballancer
