distributor question
Old Apr 19, 2012 | 05:32 PM
Pelayo114's Avatar
Pelayo114
Default distributor question
My distributor looks like its internals are all rusty and messed up. Is it better to try to rebuild it myself or should I look for a new distributor? Anyones thoughts on this?
Old Apr 19, 2012 | 05:50 PM
lars's Avatar
lars
Assuming this is a stock HEI distributor, the rusty appearance is pretty normal and usual. To get the distributor working nicely again, all you really need to do is tear it down, free up the advance mechanism, lube it, install a correctly-matched vacuum advance control unit for your engine, and slap it back together. Set the total timing up right, and you'll have a great performing unit. You can e-mail me for my papers on timing and vacuum advance to get the setup right after you free up the sticky parts.
Lars
V8FastCars@msn.com
Old Apr 19, 2012 | 05:59 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
If the shaft has a bit of play, you'd want to replace the bushings. Here's a good kit:
http://www.zip-corvette.com/ProductD...GR-SR&CTitle=&
Pretty easy. Use foot long length of 3/8"~ rod of some kind to tap out the old bushings.
This tool is handy for installing new bushings:
http://www.zip-corvette.com/ProductD...L2-SR&CTitle=&
...but I think you can manage without it.
Good luck!
Old Apr 19, 2012 | 08:02 PM
Pelayo114's Avatar
Pelayo114
Lars, is there a specific kit or method you think is good for this? I'm willing to do it all myself with a nudge in the right direction.
dark blue, thanks for the links. Ima try to get on this asap.
Old Apr 19, 2012 | 09:20 PM
scottyp99's Avatar
scottyp99
I think Lars mentions that in his paper on setting timing, just send him an e-mail, he'll hook you up with the 411.
Keep the shiny side up!
Scott
Old Apr 19, 2012 | 10:38 PM
Pelayo114's Avatar
Pelayo114
Awesome. Sent him the email right now
Old Apr 20, 2012 | 09:31 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Do you need to rebuild your distributor? Is your car running fine as is?
Old Apr 20, 2012 | 11:05 AM
Pelayo114's Avatar
Pelayo114
My car runs ok but I feel it can do better. I've already sent out my carb to get rebuilt. And meanwhile that's away I wanted to do the distributor, to get it functioning properly.
To distributor question
