Hooker max flow inserts
Old Apr 20, 2012 | 05:37 AM
richiev88's Avatar
richiev88
Default Hooker max flow inserts
Well have installed hooker max flow inserts, and they sound fantastic!
They are quite loud but deep rumble tone, and car is going much better!
Removing the reverse flow inserts was a mission, several hours on a die grinder with 6 inch carbite bit.
Stoked!
Old Apr 20, 2012 | 10:09 AM
MelWff's Avatar
MelWff
too late now but did you try dropping the side pipe open mouth down repeatly on a piece of wood. I've done this multiple times to remove inserts.
Old Apr 20, 2012 | 10:41 AM
U17's Avatar
U17
Yep, I did the "drop" method when pulling the Hooker inserts out and installing the "Sweet Thunders" ...
Old Apr 20, 2012 | 02:01 PM
AV8RSVT#1's Avatar
AV8RSVT#1
Default I agreeeeeee!!!!!!!!!!
I just installed max flow inserts in my newly purchased side pipes and I couldn't be happier. The coments from other people is the same!!!!!
Old Apr 20, 2012 | 03:34 PM
richiev88's Avatar
richiev88
The old inserts were welded in 6 places, both ends, and the welds were stainless steel, the welds on the exit were difficult to get at
Old Apr 20, 2012 | 03:41 PM
MelWff's Avatar
MelWff
wow, my sympathies, any idea why the excessive welding?
Old Apr 20, 2012 | 04:18 PM
richiev88's Avatar
richiev88
Over zealous wee man with a mig gun......
Strange because the reverse flow inserts were interference fit and tight so no welding was needed.
I did put one tack weld on the hookers...just incase
Old Apr 20, 2012 | 04:38 PM
worship79's Avatar
worship79
We need audio!!
Picking mine up tomorrow!
Old Apr 20, 2012 | 06:54 PM
palmbeachvette76's Avatar
palmbeachvette76
Originally Posted by worship79
We need audio!!
If you're just wanting to hear Max Flow inserts then here is a vid I shot in February
http://www.youtube.com/watch?v=51wm5...69AUAAAAAAAAAA
Old Apr 20, 2012 | 09:11 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Sweet '76 there, but the video stops just when it starts getting interesting.
Here's another clip of them in a BB on the road...
Yes, indeed, a set of MaxFlow's for my BB Hooker sidemounts are definitely high on my wishlist.
Old Apr 20, 2012 | 09:21 PM
U17's Avatar
U17
Maybe a little off topic but Sweet Thunders has audio of it's products also ....
Old Apr 21, 2012 | 02:49 PM
worship79's Avatar
worship79
Old Aug 4, 2012 | 04:40 PM
worship79's Avatar
worship79
Finally have her running. These things are LOUD!!
I really love 'm, but I'll get in trouble with the law fast driving around like this. Any tips for toning it down a notch?
Old Aug 6, 2012 | 05:30 AM
richiev88's Avatar
richiev88
Go faster, at about 80 mph sound seems lessen!
Old Aug 6, 2012 | 05:39 AM
worship79's Avatar
worship79
Lol! Found some good tips at several biker forums, they build their own absorption mufflers often as it seems. Will post results of course
Old Aug 7, 2012 | 05:34 AM
palmbeachvette76
I ditched the Max Flows for the same reason and asked Eric at Classic Chambered exhaust in Michigan to build me a set of his VettePacks to fit the side inserts and they sound awesome with have good volume but not as loud and annoying a tone as the Max Flows.
Old Aug 7, 2012 | 12:24 PM
TheSkunkWorks
How about an audio or video clip so we can hear them?
To Hooker max flow inserts
Old Aug 7, 2012 | 12:34 PM
palmbeachvette76
http://www.youtube.com/watch?v=_Y-MT...2&feature=plcp
Old Aug 7, 2012 | 12:46 PM
TheSkunkWorks
Perfect.
So, on a scale of 1 to 10 for loudness, with the MaxFlows a 10 where would you rate the VP's?
Old Aug 7, 2012 | 12:51 PM
palmbeachvette76
Originally Posted by TheSkunkWorks
Perfect.
Probably 8, the main thing is the tone difference. The vettepacks still have volume at WOT but it's not the deep, deep never changing tone that the max flows have. You couldn't tell the different RPM sounds an engine makes with the max flows but the vettepacks you get that good running through the RPM range tone changes.
