Is this clutch toast ?
Old Apr 21, 2012 | 10:37 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Is this clutch toast ?
Been behind some pretty powerful motors over the years, I's been so long I know it's a CenterForce but 1 or 2 I don't remember it has the centrifugal weights
Old Apr 21, 2012 | 10:50 AM
lars's Avatar
lars
Wayne -
It doesn't quite go in the "toast" category, but it does have some wear. The radial lines in photo 1 are pretty pronounced when the disc is new, and you're down to almost no radial lines towards the outer diameter of the disc. Looks like you've used the disc to its limits.. Unless you're really desperate, I wouldn't put that one back in the car again. Looks lke it has held up well, and there's no evidence of slippage or burning, so it's probably a good match for the engine & car.
I've started using the McLeod Twindisc (RST) systems on my higher torque engines, and it's a really sweet setup if you can get past the pricetag.
Lars
Old Apr 21, 2012 | 11:27 AM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
Hi MH,
Lars makes logical points and I also agree. In the second picture, the pressure plate-side material is almost worn to the level of the top of the rivet(s) and is the primary reason why that disc can be retired.
It's evident that the clamping force of the pressure plate is tightest at the outside edge of the disc as it engages and locks up. That's what the weights on the pp fingers promote (a good thing).
I agree that you got your nickel's worth out of that disc.
Old Apr 21, 2012 | 11:37 AM
gdh's Avatar
gdh
I thought we both put CF 2's in around the same time, time for a replacement for sure.
Old Apr 21, 2012 | 11:42 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
A new disc at this point. The flywheel and pressure plate are probably ok.
Old Apr 21, 2012 | 01:16 PM
MotorHead's Avatar
MotorHead
Yes we did, don't slip the clutch or let it slip, I make sure when I engage the clutch it is engaged. Would you believe this clutch has been on my 300rwhp 355ci, 420 rwhp 406ci and still holds my 600hp 427 but you guys are right, it is done, I can see some copper threads on the backside I think it is close to 10 years old and I am buying the same clutch again.
I am buying drag radials and I am going to see what number this car can put down, I got my monies worth on the paint. I know it's going home on a trailer
Old Apr 21, 2012 | 01:19 PM
MotorHead's Avatar
MotorHead
Flywheel is OK and so is the pressure plate so I'll probably just get a new disc
Old Apr 21, 2012 | 01:35 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
That is the funniest thing I have read in awhile! I love it! Make sure you post pics of the carnage Wayne!
Old Apr 21, 2012 | 02:35 PM
brando1118's Avatar
brando1118
That's exactly what I was thinking. Wayne, what kind of rear end do you have? Your motor is so powerful it might blow chunks of ring gear clear across the Canadian border if you hook up real well, LOL! Be careful man and post some time slips when you are done.
Old Apr 21, 2012 | 03:11 PM
BB72's Avatar
BB72
Hey Wayne, let me know when and where and the wife and I might fly up there and watch you run, I might have the car done by then. New disc for sure, you don't want to pull that apart anytime soon.
Rob
Old Apr 21, 2012 | 08:18 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
I think it looks more like a waffle than toast.
To Is this clutch toast ?
