low brake pedal?
Old Apr 22, 2012 | 09:45 AM
kkperformance's Avatar
kkperformance
Default low brake pedal?
74 c3 with stock engine-for now. Trying to bleed the power brakes. Have replaced 3 of 4 calipers for leaking and new master cylinder. Pressure bleed, pumped by foot, vac bleed, pressure bleed. 3 GALLONS later i still have a poor pedal-any tricks out there. Could the pads be compressing or the calipers moveing? Have bleed all 6 bleeders- 2 front and 2 rear and also master cylinder.
Old Apr 22, 2012 | 09:53 AM
hugie82's Avatar
hugie82
Check your rotors for straightness and you really should get the last caliper.
Old Apr 22, 2012 | 02:04 PM
kkperformance
No brake rotor pulsation at all, just a poor pedal
Old Apr 22, 2012 | 02:11 PM
Big Block Dave's Avatar
Big Block Dave
Might as well do that last caliper to rule it out, but perhaps your rubber hoses are in bad shape.
I just changed both rear calipers and corresponding rubber and steel lines. Gravity bled and then bled with neighbor's foot. Ive got good brakes for the first time.
Old Apr 22, 2012 | 02:49 PM
Peterbuilt's Avatar
Peterbuilt
Originally Posted by kkperformance
74 c3 Have bleed all 6 bleeders- 2 front and 2 rear and also master cylinder.
There are two bleeders on each rear caliper.
Bleed the inner first then the outer.
Did you bench bleed the new master cylinder?
I agree, replace the last caliper and the 4 rubber lines.
Old Apr 22, 2012 | 03:05 PM
Paul L's Avatar
Paul L
You haven't said what you mean by a "low/poor" brake pedal.
Old Apr 23, 2012 | 01:32 PM
kkperformance
You have to push the pedal over 1/2 way down before you even get any resistance. Bench bled master cylinder and bled the crud out of system. Never gave it a thought about the hoses flexing.
Old Apr 23, 2012 | 04:30 PM
myk7's Avatar
myk7
How much play do you have in the brake pedal? lift up on the pedal, should have at least 1/2 inch I imagine.
Old Apr 23, 2012 | 04:55 PM
brando1118's Avatar
brando1118
Hiya,
First: Replace that last caliper. It's been said to replace it in just about every response on this thread so it's obviously important.
Second: The typical parts stores that sell us a master cylinder don't realize that our master cylinders came with a deep hole and a shallow hole for the push rod that resides between the master cylinder and the brake booster. I would compare the depth of the hole between your new master cylinder and the one that you removed. If they are the same, that still may not be the answer if your brakes were performing poor to begin with. The PO if there is a PO could have put the wrong master cylinder on and just suffered through terrible brakes. I went through this same BS and when I got it sorted out I had brakes that were respectable.
Good Luck!
Old Apr 23, 2012 | 05:01 PM
damoroso's Avatar
damoroso
Do you get air out of the system when you bleed it? Do you get fluid out of each bleeder? Does the pedal ever pump up when you bleed it? Are bleeding with the engine running or off?
What I'm looking for is 1) the fluid is getting to all parts of the calipers, 2) the master is working properly (even though it's new, doesn't mean it's good) and if the brakes are bleed with the engine running, it's difficult to tell when you're actually moving the master cylinder making it highly likely you're sucking air as well as pushing brake fluid.
And finally, I don't mean to offend but maybe your bleeding procedure is wrong?
When these systems are working properly they're actually pretty good. A good firm pedal and plenty of stopping power for a stockish car.
Old Apr 23, 2012 | 06:45 PM
Paul L's Avatar
Paul L
Sounds normal with vacuum boost.
Old Apr 23, 2012 | 09:31 PM
my 76 ray's Avatar
my 76 ray
I just went through this with my '74. When I was bleeding my brakes and "testing" the pedal, it seemed like there wasn't enough pedal. But when I drive it normally, the car will stop with the pedal at about the height of the gas pedal. That's about where it is on my '76 and in fact on my brand new 2012 Subaru Legacy. Even on the Subaru if I push the pedal hard with the engine running, I can push it almost to the floor. I think we all look for a good hard pedal, but it just doesn't work that way with power brakes. Hopefully, you have a big space where you can test it without danger of hitting anything if your brakes aren't working. I have the space to test drive it.
Old Apr 24, 2012 | 09:23 PM
75vetteman's Avatar
75vetteman
From: some hole in the ground town- camp verde:) arizona
Originally Posted by brando1118
Hiya,
Good Luck!
i had this same problem with mine
Old Apr 24, 2012 | 09:46 PM
kkperformance
pedal goes 1/2 way before i get anything, feels like its 1/2 off floor when i push firm to stop. NO air when bleeding. correct procedure and clean fluid at calipers, I will replace the last caliper and rebleed. the pedal NEVER pumps up when bleeding, or i mean if you pump it it does not get better. Just wanting to make sure there is a problem as this is my first c3.
Old Apr 25, 2012 | 08:41 AM
bryanpl123's Avatar
bryanpl123
If you are no longer getting air and fluid is flowing then I would seriously look at replacing all 4 rubber lines as they can flex/bulge with age.
To low brake pedal?
