1968 automatic "bump"
Old Apr 23, 2012 | 05:23 PM
DESI6327's Avatar
DESI6327
Default 1968 automatic "bump"
Anybody know what's up here?
Shifting from Park to Drive or Reverse, I experience a hard "Bump" I'm told that it's "The nature of the beast" by a Corvette Mechanic that I trust. I'm bringing the car in soon to check this out, but the U Joints are fine, the Snubber is as well....
Any ideas would be appreciated
BD
Old Apr 23, 2012 | 05:54 PM
bashcraft's Avatar
bashcraft
What's the idle speed?
Old Apr 23, 2012 | 08:41 PM
DESI6327's Avatar
DESI6327
Idle speed was at 900 RPM..we dropped it down to around 6-700...Just a tiny bit better, but still there
Old Apr 23, 2012 | 09:16 PM
my 76 ray's Avatar
my 76 ray
The rear end will squat a bit when you shift to drive, but it shouldn't make any noise
Old Apr 24, 2012 | 12:58 AM
DESI6327's Avatar
DESI6327
This is a definite "Bump!" Like the RPM's are high when shifting into gear. I guess I'll see when I bring her in.
I'm also told that GM had a memo that went to all dealers, told them to NOT try to fix...That the car will experience some "Lash" in the drivetrain components over time...U Joints, Half Shafts...etc
Any help would be appreciated...
BD
Old Apr 24, 2012 | 06:57 AM
bashcraft's Avatar
bashcraft
Lash? That's called worn out parts, and the memo to not fix it I'm sure is BS. Who told you that?
Old Apr 24, 2012 | 10:51 AM
DESI6327's Avatar
DESI6327
It was posted on another forum...Not the actual "Memo" I'm glad you think it's BS..I got the same feeling. If I can remember which one it was on, I'll post it. The more I read about Snubber Cushions, the more I think this is the culprit.
Old Apr 24, 2012 | 10:54 AM
bashcraft's Avatar
bashcraft
That would be the first thing I'd check.
Old Apr 24, 2012 | 09:16 PM
75vetteman's Avatar
75vetteman
From: some hole in the ground town- camp verde:) arizona
thm350s have an anticlunk spring. designed to cushion the shift into gear from park... this does not cushion the shift from 1st to 2nd or 2nd to 3rd etc. as that is the job of the accumulator.
thm400s don't have this spring
Old Apr 24, 2012 | 09:23 PM
pricesgarage's Avatar
pricesgarage
probley the internal lip seals leaking due to age they get brittle and let transmission fluid by pass making a slight delay then the increased psi to aplly the clutches makes them apply rouughly also worn friction plates in the tranny will make a clunk when its engauged into gear
Old Apr 24, 2012 | 10:44 PM
Ironcross's Avatar
Ironcross
the idle is 'too high and there is no stall in the converter....he probably has to hold the brakes firm at a red light or in anything except neutral and shut it off in gear
Old Apr 25, 2012 | 12:26 AM
DESI6327's Avatar
DESI6327
Actually, that's not the problem. It's fine while driving. No problem there. Just shifting from P to D or R. Sits nicely at a light, shifts through the gears with no problem at speed....and punching it is fine as well...Shifts through all gears with no problem.
It's a 427/390
Old Apr 25, 2012 | 12:29 AM
DESI6327's Avatar
DESI6327
The engine is a 427/390. As I mentioned in another post, everything else in the tranny seems to work fine. Sits at a light with no problem, accelerates through the gears with no "Bump" at all. Nice and smooth. Just going from P to D or R
We shall see.
Thanks for all the info
Old Apr 25, 2012 | 07:11 AM
63split63's Avatar
63split63
Is the snubber a stock rubber one or a hard polly one ?
Bill
Old Apr 25, 2012 | 07:53 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
We shall see.
My 427/390 gives me a little bump shifting especially into reverse but I think it's just the nature of the beast. If your snubber is OK and you keep your idle down you still get a little bit of a bump but not a clunk. Your idle should be around 650 RPM's in gear and around 800 RPM's in neutral and park.
Old Apr 25, 2012 | 12:15 PM
DESI6327's Avatar
DESI6327
Bill
Good question....don't know. Bought the car last week, and it's on it's way here now via transport. Like I mentioned, my mechanic thinks it's probably the Snubber. It's going in as soon as it gets here. Everything else about the car is great....
Old Apr 25, 2012 | 12:17 PM
DESI6327's Avatar
DESI6327
Yeah..this car was idling at 900...we dropped it down to around 6-650..Made a little difference, but not a lot. I'm still guessing it's the Snubber. The seller showed me all receipts for work done...LOTS!!! One thing he never addressed WAS the snubber...Said he "Eyballed" it, and it looked OK...Still think that's the culprit
To 1968 automatic "bump"
Old Apr 25, 2012 | 12:47 PM
Jclgodale3's Avatar
Jclgodale3
Old Apr 25, 2012 | 01:28 PM
Ironcross's Avatar
Ironcross
Its not the transmission, as it should not make a substantial RPM change going between park and reverse or the others....the converter regulates that...a hydraulic cam {stock} should be in the 500 RPM range in and out of gear at idle.......If a hot or hotter cam is in the engine then a stall converter will cure the noise....if the above replys happen to be incorrect
Old Apr 26, 2012 | 03:35 AM
DESI6327's Avatar
DESI6327
Thanks, Iron...
According to the receipts for the engine rebuild, a non stock cam was replaced by a stock one. The engine doesn't act like it has anything radical in it, however, when we dropped the idle down, the engine sure labored.
SNUBBER.....that's what I'm thinkin'!
