Borgeson Vs rack and pinion
Old May 9, 2012 | 10:37 PM
  #41
427V8's Avatar
427V8
C6 the C5 of tomorrow
Originally Posted by oldalaskaman
in my research on these I found that ford installs a restrictor valve in the base of their pressure line, seems they have some pressure issues also, wonder if that would be an option on your setup?
Gm makes an adjustable power steering valve that just screws into the back of the pump
The best part is you can just hook up 12 volts to is and instant stiffer steering
Look on older saturns
Old May 10, 2012 | 02:51 AM
  #42
Gale Banks 80''s Avatar
Gale Banks 80'
I believe that Flameing River makes a reduced Flow PS Pump just for this problem. Lets everybody keep in mind that this is for use with the Gen II Pump not a Pump that ever came in a C3. Oddly enough theres is the Cast Iron version and not the Aluminum one. The Pumps also have some restrictor Valves built in that one could play with. I figuered that I would let somebody else figure this out wile I worked on other projects, and I think FR has done it for me.
Old May 10, 2012 | 09:23 AM
  #43
oldalaskaman's Avatar
oldalaskaman
excellent tech.
Old May 10, 2012 | 10:17 AM
  #44
Solid LT1's Avatar
Solid LT1
Originally Posted by mrvette
Best of luck, Old Frozen Critter,...... my rack been my '72 for ten years now...never had a issue, knock on wood, Mahogany....
OK tell us how many miles on your R&P conversion. A simple search titled "steeriod problem" will bring up multiple threads in this C3 forum. I don't think.doing the same search will bring up any for the Borgeson.
Old Jun 8, 2012 | 06:26 AM
  #45
jerome1979's Avatar
jerome1979
excellent many thanks, I'll keep playing with it
got the e-mail , that $100 less than the best price I could find, many thanks, bob
where ???
Old Jun 8, 2012 | 10:25 AM
  #46
forvicjr's Avatar
forvicjr
I did my conversion with a new 02 grand cherokee box and a chevelle pitman. I have a big block so the plate kit wouldnt work for me(header clearance) I had to cut the frame and box it in to get everything in place. Got around $400 in the whole thing. All is good but anything over 90 mph the steering is dangerously sensitive and ive also noticed that under hard braking from high speeds it wants to wonder a bit. figure Ill add some caster and see what that does. I love it at cruise speeds though.
Old Jun 8, 2012 | 01:49 PM
  #47
mrvette's Avatar
mrvette
In a bit over ten year, I"m going to say about 60k miles...it's a DD ....
trick is, I did the rack before any kits were out, my brackets are much simpler, and seem to be hanging in there....
