weird dome light
Old May 3, 2012 | 10:40 PM
junkman123's Avatar
junkman123
Default weird dome light
can any on tell me where this dome light should go on my 79 and why its hanging out with the back tail lights?i have looked every where in the back of the car,and theres no where it can go
Old May 3, 2012 | 11:54 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
That's either your license plate light or spare tire light.
Old May 4, 2012 | 12:07 AM
junkman123's Avatar
junkman123
it comes on when i open the door and goes out when i close it,and the wiring diagram i got from a member here says the orange wire and white wires are a dome light,the tag light is the one hanging with it
Old May 4, 2012 | 03:08 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
It's. The. Spare. Tire. Light.
There should be a bracket over the spare tire somewhere to mount it, it uses the same lens as the license plate light. How could it possibly be a "dome" light when it's behind the gas tank?
If your wiring diagram doesn't show the spare tire light, you need a better wiring diagram.
Old May 4, 2012 | 04:53 AM
junkman123's Avatar
junkman123
here is the diag. i have. the dome light is listed in the lower right 1/4 of page 2 with the tail light wiring. so if it is the spare tire light is it correct to come on when the door opens and off when it closes with the interior light?this is my first vette.i'm used to rebuilding camaros and chevelles.
Old May 4, 2012 | 04:57 AM
junkman123's Avatar
junkman123
blah its to small to see,try this one
Old May 4, 2012 | 07:28 AM
MIKE80's Avatar
MIKE80
You are missing this lens for the bulb. I believe it screws to the bottom/ center of the rear bumper to provide light for removing the spare tire while changing a flat.
http://www.ecklerscorvette.com/corve...-1995-zr1.html
Old May 4, 2012 | 07:35 AM
...Roger...'s Avatar
...Roger...
Those generic diagrams can't always be trusted.
Old May 4, 2012 | 09:03 AM
BKarol's Avatar
BKarol
Is this what you are missing?
Kaps has the best pics
According to the owners manual when you turn the headlight switch counterclock wise the dome and spare tire light should come on.
Old May 4, 2012 | 12:38 PM
junkman123's Avatar
junkman123
thanks karol,that looks like what im missing
Old May 4, 2012 | 01:57 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
It's the same lens/housing as the license plate light. Yes, it's on the same circuit as the dome and courtesy lights.
Old May 4, 2012 | 02:28 PM
540 vette's Avatar
540 vette
And then if you take a while to change the tire you have a dead battery.
Old May 4, 2012 | 06:05 PM
junkman123's Avatar
junkman123
yup,thanks for everyone's help
To weird dome light
