C3 color chart for frame
Can you guys tell me where I can find an OEM color chart for painting the correct colors for my frame parts. Example, Disc brake covers, spindles, rear leaf spring, drive shafts, rear end etc. I looked at a Eastwood catalog and it has a picture of a corvette frame with their colors. I'd like to find a OEM chart for matching the colors if possible.
Head over to the NCRS site. They will tell you everthing about anything Corvette.
I told a friend to do it for his 68 and he's thrilled by the quick responses to even minor questions. BTW I think he joined the NCRS and got a lot of documentation for a 68.
Except for the frame itself, nearly everything attached to the frame is bare or plated metal. Do you want to keep it exactly the same as 'factory original', or do you want to paint everything a similar color as from the factory, but keep them protected from rusting?
You can find the info on the original color of stuff at the NCRS site, but they will have NO information about what paints/colors to use in order to "simulate" factory colors. They don't allow that sort of thing. {I guess they like rust and corrosion....}
Thanks guys
The judging manuals simply describe what the original materials and finishes were. Imagine that! If you want to know how to rebuild an SBC or how to paint a car in BC/CC to look like lacquer, that's the wrong book.
The vast majority of members have 'daily driver' cars that may never be judged and have restored them according to their desires and budget, as they see fit. Questions like yours appear frequently on the NCRS board and get answered courteously as KenSny mentioned. There are all sorts of methods of redoing unplated/unfinished surfaces to look similar to factory stuff.
I think that's what I already told him, Mike. NCRS will tell him what the 'original' finishes were. Now, you've told him and I've told him. You think that's enough for now????
By the way, did I tell him incorrectly that NCRS would not advise of any kinds of paint that would replicate the 'appearance' of factory finish?
Didn't think so.....
Received 2,878 Likes
Hi qm,
While many of the parts that make up the running gear are 'natural', a surprising number of parts were painted, too. The shock absorbers, front sway-bar, rear caliper mount, trailing arms, to name a few.
Also, there were some parts that were originally plated with various finishes. The front caliper mounts, and brake splash shields for example.
If you're interested in original finishes you should think about the fastener finishes too. Bolts, washers, nuts, etc. were 'natural', black oxide, phosphate and zinc depending on where they were used.
Cars are restored to different levels of original accuracy depending on the owner's desires.
It's one of those things that you can get as deeply into as you want.
Good Luck!
Regards,
Alan
Good Luck!
Regards,
Alan
I want to thank you guys for your input. I'm doing a ground up restoration on my 1970 LT1 Convertible and trying to get it correct as possible. I had the frame powder coated in chassis black and I'm starting to install parts on the frame.
I might have it judged when it's completed to improve the value.
Good luck with your project.
Come on guys, let's give credit where credit is due.
The NCRS guys have compiled a lot of info over the years.
And no, I don't follow the NCRS guidelines, I like to do it my way. But for those that want to know the way GM did it, they are the go-to guys.
My advice: Don't sit here on the forum and asked pure GM OEM restoration questions, you will probably get many different answers. Sometimes correct - sometimes not.
Lets be
Lets be
sug (01-11-2017)
As others have said, powder coat on the frame is going in the wrong direction.
Received 1,469 Likes
Cruise-In II Veteran
Hi qm,
If you begin to attend some NCRS you may well run into some examples you can study to see if they apply to what you're doing with your LT-!.
These are from last Summers NCRS National Convention in Novi Michigan.
The chassis and running gear was displayed by Kevin McKay.
I think seeing original and restored cars in person offers MUCH more information than can be related in lists. (Although lists are good too!)
Regards
Alan
Regards
Alan
If you don't want to prepare the car exactly as NCRS requires (for it's scoring process), you may be sorely disappointed with the scores you receive..even though you do a marvelous job of restoring your car.
You need to get a copy of the judging manual, review it, then decide how to best proceed.
Not a problem. Everyone should do what they think best with their car. But, newbies..or folks just starting to think about how they want to restore their car, need to consider all the issues before setting a course for either 1) pure factory condition (NCRS); 2) simulated factory condition; or 3) "mod" as desired. All are good; but, some are more difficult, and some are expensive and nearly impossible.
Everyone who asks 'the question' deserves to know what they are in for.
Another thought about the 'have it judged to improve the value' topic. Putting aside the negative impression that it gives us NCRS guys, be aware that the additional costs of getting everything just right for judging, and keeping it that way rarely gives any positive payback at time of sale. Although there are some people that won't know the difference between a Third Flight Chapter award and Top Flight National, most knowledgeable buyers will. The costs of campaigning a car to a National event are considerable.
There's also the aspect of making the car undriveable for fear of getting a stone chip or corrosion following a rainstorm. Committing to a full blown restoration is not for the faint of heart.
