door vspor barrier
Old May 10, 2012 | 03:05 PM
Scott Marzahl's Avatar
Scott Marzahl
Default door vspor barrier
What do you guys use for vapor barrier, hate to spend $30 a pair from vendors will poly sheet from home depot work in this application
Old May 10, 2012 | 03:07 PM
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
6mil poly sheet from Home Depot and a thinly cut strip of window weld.
Old May 10, 2012 | 03:09 PM
TimAT's Avatar
TimAT
I'd get the really heavy plastic sheet at Home Depot or somewhere like that. Problem is that you can get 100 yards for that same $30, so if you don't have a real other use for the extra, is it worth it?
I'm not real concerned about being original either, so that also is a factor in my decision
Old May 10, 2012 | 03:58 PM
Scott Marzahl
I've got a 100 foot roll of 6 mil for painting the house I can use. Thanks, irs not like its exposed to UV and will break down
Quickly
Old May 10, 2012 | 03:59 PM
Scott Marzahl
Got a 100 foot will for painting the house
Old May 10, 2012 | 07:10 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
I used the Reflectix, from lowes for the door panels,
cut them to fit and secure with foil tape, my doors are completely sealed and insulated !
good luck.
Old May 10, 2012 | 08:46 PM
Scott Marzahl
Good idea, are they any quieter?
Old May 10, 2012 | 10:49 PM
7T1vette's Avatar
7T1vette
Uhhh....I don't drive in the rain??? I don't find them to be a necessity.
Old May 11, 2012 | 02:04 AM
babbah's Avatar
babbah
I have these installed: http://www.ecklerscorvette.com/corve...1963-1967.html
Old May 11, 2012 | 08:39 AM
Alan 71's Avatar
Alan 71
Hi Scott,
I'm not sure just what your goal is.
In most cases any plastic vapor barrier will do just fine.
I'll only mention that the original vapor barrier was vacuum formed to match the profile of the door panel and the various door and window mechanisms under it. I don't know if that matters to you or not.
I believe it was originally held in place with a material very much like the black 3M strip caulk.
Regards,
Alan
Old May 11, 2012 | 08:59 AM
RobbSalzmann
St. Jude Donor '12
Regards,
Alan
This is what I meant by "window Weld". Thanks Alan
Old May 11, 2012 | 03:57 PM
71rdster's Avatar
71rdster
If you have modern replacement door panels with plastic backing, I don't think the vapor barrier is a real necessity. However,if you have original style press board backed door panels, you may want to have the vapor barrier to protect them.
Old May 11, 2012 | 08:26 PM
Solid LT1's Avatar
Solid LT1
This person is a mind reader! Glad I don't play poker with him.
Old May 11, 2012 | 09:40 PM
terry82's Avatar
terry82
i taped over the holes with hvac tape.
To door vspor barrier
