Muncie install question
Old May 10, 2012 | 09:10 PM
tyrant's Avatar
tyrant
Default Muncie install question
I am attempting to install my Muncie and bell to the motor. When I slide the trans in it stops about a half of an inch before the bell hits mounting surface. I have never done this before so any help would be appreciated.
They are both currently out of car I am going to put in together. Thanks
Old May 10, 2012 | 09:39 PM
restoman1's Avatar
restoman1
Did you line up the clutch disk using an alignment tool? That will stop it from going in all the way.
Ed
Old May 10, 2012 | 09:44 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Best to have a clutch alignment tool or spare input shaft (even better) so you can get everything lined up with the pilot bushing in the crank before attempting to install the trans, but if you have a way of releasing the clutch (as in pushing the pedal) while you slide the trans in you should be able to get there. Whatever you do, don't force the issue by tightening the bolts to pull things together.
FWIW, if assemblying any engine and bell combo that has never been together before (and sometimes even then) you necessarily should check concentricity and squareness of the bell to crackshaft centerline.
Old May 10, 2012 | 10:01 PM
tyrant's Avatar
tyrant
The engine and trans came out of a 1970 vette, the clutch is like new so it has not been taken off the flywheel. Shouldn't it go back in without having to realign disc? It is in gear should it be in neutral when I attempt again?
Old May 10, 2012 | 11:12 PM
Lee H's Avatar
Lee H
Is the input shaft bushing in the crank shaft installed properly?
Old May 11, 2012 | 07:26 AM
tyrant's Avatar
tyrant
It should be it was just taken out of the car a few weeks ago.
Old May 11, 2012 | 07:28 AM
gcusmano74's Avatar
gcusmano74
Put the trans in 4th gear before you install it. With the output yoke in place, you will be able to turn it and align the splines, assuming the clutch disc is perfectly centered on the flywheel. Check it first with an alignment tool, or a spare input shaft.
Old May 11, 2012 | 07:35 AM
tyrant's Avatar
tyrant
I will pick up an alignment tool today. Is there a way to put it in fourth without the shifter?
Old May 11, 2012 | 08:25 AM
6t7gto's Avatar
6t7gto
Any gear will work.
Just so you can rotate the output as you install the trans.
Pair of pilers will move the shift forks.
Old May 11, 2012 | 09:59 AM
moosie982's Avatar
moosie982
Has the trans in question ever been mated to the motor ? Does the clutch disc and input shaft have compatible splines ? I've always found it easier to do it separately, bolt the bell housing to the motor and then the trans to the bell housing but thats just me. Good Luck, Peace,,, moosie
Old May 11, 2012 | 10:47 AM
shmoky's Avatar
shmoky
I had exactly the same problem 2 days ago. Had someone engaged the clutch half way and it just popped/slid into place. Good Luck.
shmoky
Old May 11, 2012 | 12:13 PM
TheSkunkWorks
Originally Posted by moosie982
...I've always found it easier to do it separately, bolt the bell housing to the motor and then the trans to the bell housing but thats just me...
Here too. I've always setup the clutch, then installed the bell (verifying true), then installing the box.
Old May 11, 2012 | 12:26 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Install bell housing to motor.
Select fourth gear by moving forward shift lever forward. Second shift lever should be almost straight up. Reverse shift lever forward.
Now get 3 4" long 1/2 inch bolts(IIRC) cut the heads off them.
Thread them into the bell/trans mounting holes. At the top right and both lower holes.
Stab trans using the headless bolts as alignment pins. If your clutch and pilot bushing are aligned the trans should slip right in, you may have to rotate output yoke to align splines.
If trans wont go that last 1/2" DON'T FORCE IT OR DRAW IT IN WITH BOLTS!!!
Use a ratchet strap attached to clutch fork and a rear frame hole , tighten the ratchet strap(simulating pushing the clutch pedal in).
After mating trans a bell. remove dowell pins and install proper bolts to req torque.
Here's a timesaver tip. Clean shifter rod threads and install shifter alignment tool prior to installing shifter.
Old May 11, 2012 | 09:45 PM
tyrant's Avatar
tyrant
I picked up the alignment tool it went in easy until the pilot bushing then it seemed tight. It went in all of the way but needed force to pull out. They are matching pieces from the same donor. I am attempting this on the floor of a garage they are not in car.
Old May 12, 2012 | 07:53 AM
Garys 68's Avatar
Garys 68
If the cheap plastic alignment tool binds, the input shaft probably wont fit. Unbolt the pressure plate and position the disk with the alignment tool. Be sure to use loctite and torque the pressure plate correctly.
Old May 12, 2012 | 08:04 AM
Indiancreek's Avatar
Indiancreek
Here's a timesaver tip. Clean shifter rod threads and install shifter alignment tool prior to installing shifter.[/QUOTE]
A lot of tranny ears come off in that last 1/2 inch.
Old May 14, 2012 | 09:11 PM
tyrant's Avatar
tyrant
Got it!!! Adjusted the clutch an it went right in. Thanks for all the help guys.
To Muncie install question
