Fully loaded control arms?
Old May 14, 2012 | 01:50 PM
MacVette86's Avatar
MacVette86
Default Fully loaded control arms?
I would like to redo my front suspension myself, but don't have access to a press, etc. I believe the only place I'd need special tools would b to press in the control arm bushings and ball joints. So, can you buy control arms that already have the bushings and ball joints installed?
Old May 14, 2012 | 02:14 PM
lars's Avatar
lars
You can e-mail me for a copy of my "How to Rebuild Your Front Suspension" paper for complete instructions on how to do the front end rebuild with no special tools other than an air chissel and a cheap 3/4" drive socket set.
Lars
V8FastCars@msn.com
Old May 14, 2012 | 08:16 PM
MacVette86's Avatar
MacVette86
While looking around for front end suspension parts I discovered that VanSteel does indeed sell the complete upper and lower control arm assembly with poly bushings and Moog ball bearing installed. All this for $169.99 minus the 10% forum discount.
http://www.vansteel.com/index.cfm?fu...up=102&ID=3258
http://www.vansteel.com/index.cfm?fu...up=102&ID=3262
Old May 14, 2012 | 10:03 PM
oldalaskaman's Avatar
oldalaskaman
I 'm going out on a limb ,but, if you dont have the experience to do the bushings, actually the easiest part of the job, caging the spring, separating the ball joints from the spindle and then re-installing everything is possibly not the best thing for you to do. For the money you'll spend on your loaded control arms , you could take it to a shop and have it done right, and you wont start a project and not be able to finish it.
btw, just did my complete front suspension , with out special tools or air chisel, but I've been doing it for years.....and years
Old May 14, 2012 | 10:07 PM
Shark Racer's Avatar
Shark Racer
I have never done press fit bushings before, but none of the rest of the job scares me.
Old May 14, 2012 | 10:11 PM
oldalaskaman
there's a neat trick, serious old school
Old May 15, 2012 | 01:55 PM
MacVette86's Avatar
MacVette86
Rebuilding the front suspension doesn't wrry me, I'm a fairly competent back yard mechanic(: The reason I was interested in the fully loaded control arms is simple convenience. For $155 per side (after forum discount), I get a new control arm with bushings installed and a Moog ball joint. Basically, unbolt the existing arm and bolt the new one in. Seems worth it to me.
Old May 15, 2012 | 02:01 PM
Marlin's Avatar
Marlin
Do you want poly bushings? You can always buy the bushings and have a machine shop press them in.
Also the ball joints are bolted in, not pressed.
Old May 15, 2012 | 02:04 PM
Shark Racer
Unless they're original or were installed by an NCRS type, which would make them riveted.
Old May 15, 2012 | 02:25 PM
BB72's Avatar
BB72
Lars
V8FastCars@msn.com
I agree with Lars. I would add a sawsall in there for when you remove the old bushings with heat(they fall out then) you can cut the outer bushing race easy enough and install the new ones.
Rob
Old May 15, 2012 | 03:11 PM
damoroso's Avatar
damoroso
Yeah, just unbolt it and bolt the new one in......
Old May 15, 2012 | 09:06 PM
72LS1Vette's Avatar
72LS1Vette
Lars
V8FastCars@msn.com
Welcome back Lars!
Rick B.
Old May 15, 2012 | 09:26 PM
oldalaskaman
for what its worth , if I could afford to buy loaded control arms, I would.
Old May 15, 2012 | 09:52 PM
Clams Canino's Avatar
Clams Canino
Lars
V8FastCars@msn.com
I did mine using Lars' paper - twas not bad at all.
(except for the sandblasting!)
-W
Old May 16, 2012 | 12:56 PM
MacVette86's Avatar
MacVette86
Lars did send me his rebuild paper (Thanks Lars!) and I will use it as my guideline. However, I will buy the fully loaded arms from VanSteel, because for that price and the potential hassle I will avoid, it's worth it to me.
Old May 16, 2012 | 01:03 PM
oldalaskaman
wilcox has a neat tech. on how to cage the spring and make things easier.
Old May 17, 2012 | 10:50 PM
lvmyvt76's Avatar
lvmyvt76
oldalaskaman, what color is your 76? can not send any PM to you.
To Fully loaded control arms?
Old May 17, 2012 | 11:20 PM
Steve439's Avatar
Steve439
It's pretty funny, the control arms were the only thing I didn't do myself on my '67.
I did 'em on my '66 but didn't see much fun there.
It's not the enjoyment of setting up the trailing arms, it's just grunt work.
I boxed up my greasy, crusty arms and I got back pieces of art from Van Steel.
Old May 17, 2012 | 11:25 PM
John 65's Avatar
John 65
You dont need a press for this job, its really quite simple. Heres my fancy-schmansy, expensive, specialty tool from the Home Depot that I have used on dozens of these bushings. No, it does not harm the bushing or control arm at all and seats them perfectly. Its like they made this cap for these bushing. Put your control arm flat on the bench, hold it by the shaft, and seat the bushing. Very ez.
Old May 18, 2012 | 12:05 AM
oldalaskaman
Its white, not sure why my pm thingy doesnt work , I'll keep tryin,
