Gauge lights problem!
Old May 18, 2012 | 11:12 PM
csierp's Avatar
csierp
Default Gauge lights problem!
I was sitting a stop light the other night, and unprovokedly, my gauge lights died. When I turned the **** all the way to the left, my feet/head lights still popped on... But today they have crapped out on me as well.
Anyone else encountered this nonsense?
Also, just finished replacing all the weatherstripping today (Corvette Rubber)... took me two solid days and I still have gaps in the corners of the window seals >_<
Old May 19, 2012 | 08:19 AM
7T1vette's Avatar
7T1vette
The headlight switch rheostat for the interior lights "dimmer" has bit the dust. Most likely time for a new headlight switch.
Installing those seals...and getting them right...is not an easy process. I'm amazed that those "kits" don't all come with a DVD of instructions on HOW to do that job and get it right.
Old May 19, 2012 | 11:10 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 7T1vette
The headlight switch rheostat for the interior lights "dimmer" has bit the dust. Most likely time for a new headlight switch...
but check the fuses first. No sense buying a headlight switch and diving into the dash if all you need is a fuse.
Old May 19, 2012 | 06:06 PM
csierp's Avatar
csierp
Thanks for the info! I'll get to fixing that
Old May 20, 2012 | 11:32 AM
OTRider53's Avatar
OTRider53
Changing the headlight switch ...is the rheostat included in the switch? So if I've replaced the switch then the rheostat isn't the problem???
Inconsistent headlights, No dash and no tail lights...They worked for a min after replacing the switch but then the fuse blew...and blew again after we put a new fuse in...
Pam
Old May 20, 2012 | 12:23 PM
oldalaskaman's Avatar
oldalaskaman
Pam
you have a hot wire thats shortin' to ground
Old Sep 13, 2012 | 04:11 PM
Andrew74's Avatar
Andrew74
I'm having somewhat of the same problem with my 74 vette.. My guages work but the lights are out. While driving if I hit any little type of bump my gauge lights will come on and off. Which leads me to believe it's a ground issue but I can't find it can you help???
Old Sep 13, 2012 | 07:08 PM
Peterbuilt's Avatar
Peterbuilt
Default See the light!
Tail light fuse feeds the headlight rheostat.
Jumper from "Courtesy" light fuse to "Instrument" light fuse.
If the dash bulbs light up the rheostat in the headlight switch is bad.
Lights blinking:
The center gauge cluster and wiper switch (on a 74) ground through the center terminal of the "Water Temp gauge". The other end of that 14 gauge black wire connects just above the bottom of the left dash, Check that its good.
To Gauge lights problem!
