Which Carb?
Old May 20, 2012 | 11:27 PM
736cc's Avatar
736cc
6th Gear
Default Which Carb?
I recently rescued a 1970 Corvette convertable w/ a 350/4 speed. It needs EVERYTHING because previous owner totally neglected it, its been sitting for 20 years, the last 3 outside in the NY weather. Way too many bad points to list (rust and spiders everywhere, a dead raccoon was found under the hood and it ate a couple of yellow plug wires, moldy carpets, etc) but the motor turns over, and its all there original w/ 90,000 miles. The oil is clean, the sticker on the door shows that oil only has 1 mile on it since it was changed (albeit in 1991). Its going in my buds shop for a couple of days only, not for a restoration but just to get it running (and stopping) so I can bring it home for a long-term evaluation and basic going over. First thing to be done is drain the gas tank completely. I really am on a budget. The carb looks positively toast; any suggestions which replacement carb should I purchase new thats reasonably priced and ez to install and tune? My short-term goal is just to get it running again; it will never be a concours restoration, just a functional driver.
Old May 20, 2012 | 11:37 PM
mrmagrath's Avatar
mrmagrath
Why not rebuild the carb it has? That would be cheaper than springing for a new one. Is it still the original Q-Jet?
Old May 20, 2012 | 11:42 PM
merc49's Avatar
merc49
i would definately use a quadrajet, its probably cheaper for a rebuilt one than going to an aftermarket and will bolt up and run great.
Old May 20, 2012 | 11:48 PM
johnt365's Avatar
johnt365
My dear friend, I want to welcome you to our little forum and let you know that in your first post you have dug up one of the most controversial topics we have.
IF you are sincearly on a budget, then most will likely reccomend rebuilding the original quadrajet if possible.
However, if upon disassembly and thorough inspection you find irreperable damage to the stock carb, I would recommend a Holley to replace it.
If you can, please post some pictures of your new love and the carb that has you worried.
Best regards,
Old May 21, 2012 | 09:42 AM
lars's Avatar
lars
If it's the original Q-Jet and it "looks like toast," it's probably a perfectly preserved original carb that would be an excellent candidate for a nice rebuild - it's seldom that you see nice original carbs like that, so keep it and fix it. If you need assistance with it, I can rebuild it, set it up, and test it for you. You can send me an e-mail for my Services Info Sheet.
Lars
V8FastCars@msn.com
Old May 21, 2012 | 10:08 AM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default 70's carbruator
736cc it was mentioned by a poster of a Holley replacement. I replaced my 1968's Q-Jet with a Holley 6210 650 spreadbore double pumper in 1974 and still driving it today with the same Holley. The Holley 6210 spreadbore is still sold by Holley today. I like the 6210 double pumper because I have absolute complete control of the throttle application from idle to WOT.
Lars posting of his offer to rebuild your 70's carb is something to do to keep the original carb on your 70 if it is the original. From what I have read Lars does expert professional rebuilds.
I also put the same Holley 6210 650 spreadbore double pumper on my 1970 Corvette in 1974. I could not use the spreadbore on the ZZ crate engine that I installed because the aluminum intake on the ZZ crate required a square bore type carb in which I used a Holley 650 double pumper.
A new spreadbore Holley will cost you more than than what I paid for the ones in 1974. $64.00 apiece.
Old May 21, 2012 | 01:16 PM
69 Chevy's Avatar
69 Chevy
I decline to jump into the rebuild/replace carb fray. But I would like to comment on this engine oil issue:
No matter how tight your budget is, replace the oil and filter ASAP. Having only 1 mile of run time on it means nothing. It has had 20+ years of exposure to the elements sitting in the crankcase. It would be way past its shelf life even in its original container. ~5% of motor oil is the additive package which has surely broken down or precipitated out of suspension over all these years. Do not trust it to do its job.
If that car were mine, I'd replace all of its fluids.
Old May 21, 2012 | 02:52 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
On a budget, a copy of this, an over the counter rebuild kit, and some carb cleaner will be cheaper than a replacement carburetor.
Lars made an offer you should seriously consider. He's an expert with Q-Jets.
Old May 21, 2012 | 02:53 PM
Crepitus's Avatar
Crepitus
If that is a original carb what ever you do save it, it is gold to somebody, some day maby even you.
Old May 21, 2012 | 03:00 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Send it to Lars.
Old May 21, 2012 | 04:15 PM
694speed350's Avatar
694speed350
Originally Posted by 63mako
Send it to Lars.
Old May 21, 2012 | 04:24 PM
Roco71's Avatar
Roco71
Send it to Lars.
Its as simple as that
Old May 22, 2012 | 02:18 PM
736cc's Avatar
736cc
6th Gear
Maybe Lars (or somebody else here) has a good, bolt-on used carb I can buy so I can get this puppy fired-up? As for the carb on the car presently, I'll post pics to find out if its original or not. Unfortunately, I couldn't tell a q-jet from a q-tip LOL
Old May 22, 2012 | 02:52 PM
Les's Avatar
Les
That's funny! I think Lars used to keep a loaner on hand but I'm not sure if he still does. Shipping costs from Colorado to wherever you are may make that option too expensive for you but it can't hurt to look into it. Lars is the man if he can do the work for you.
Old May 22, 2012 | 03:56 PM
mrmagrath's Avatar
mrmagrath
Mate, you're lucky I offer an exchange service as well. Never mind the carb, send me your 1970 convertible, and you get my 74 convertible in exchange!
Old May 22, 2012 | 04:22 PM
birdsmith's Avatar
birdsmith
If you are interested in preserving the value of that car ('70 owner here myself) verify that the carb that is on it is the original one. If it is, send it to Lars. You do not yet know what a kind and gracious offer he has made you...most guys here practically BEG him to solve their carb woes.
Old May 22, 2012 | 04:29 PM
scottyp99's Avatar
scottyp99
Sheesh! Just rebuild the carb, it'll take less than a week doing it in your spare time. It really just involves taking it apart, cleaning the crud off of it, and putting it back together. Check out this article:
http://vetteprojects.com/kstyer/quadrajet.htm
Keep the shiny side up!
Scott
To Which Carb?
Old May 22, 2012 | 04:41 PM
joewill's Avatar
joewill
with sitting that long, the carb is one of your lesser concerns.. you'll need brakes, battery, tires, exhaust, hangers, all hoses and lines, replace all fliuds, gaskets, major tuneup, including wires, plus the carb rebuild.
find out why it was parked.. engine/tranny/clutch scattered? there is usually a reason.
do a compression test to test the engine basics before you spend alot of money.
Old May 22, 2012 | 08:53 PM
72SLEEPER's Avatar
72SLEEPER
Man lars, all ur marketing is done for you. This guy knows his stuff he has helped me out of a jam a few times and has never been wrong. I'm sending my carb to him! My .02
Old May 23, 2012 | 12:51 AM
cv67's Avatar
cv67
St. Jude Donor '05
Take a pic of the carb and post it.
If its the original carb KEEP it. These guys are trying to do you a favor by urging you to. See what lars can do for you.
