Does anyone have a good pic of where the vacuum tube for the TH400 runs? How is it supported? Is the tapered end at the tranny or at the manifold? I cant seem to get it to fit naturally..
Runs from the modulator along the tranny; tab connects to one bellhousing bolt, them comes up by the distributor and over to the intake manifold vacuum fitting. Plugs into the fitting and uses a piece of hose over the joint.
Here are some pictures of my 73 from it going back together. The fat end goes down into the diaphram at the tranny on the passenger side and the narrow end at the carb. There is an eyelet that you use to bolt the tube to the firewall. Send me your e-mail address and I'll send you pictures from mine going back together. Mike
I only have pics. of my '77. You can see it here under the dist. advance, inserted vertically. The tube inserts into the fitting, the short rubber hose provides the seal. mike...
I dont have a stock intake any more. So mine has been modified a slight bit. I have it situated somewhat naturally, but the intake end sticks up about 4 or 5 inches higher than the intake..
Which end has the tapered tip? The tranny end or the intake end?
