Strut Bar Removal Help
Old May 23, 2012 | 07:25 PM
Roco71's Avatar
Roco71
Best of luck let us know how it goes... I can show you where to cut if it comes down to it LOL.
Old May 23, 2012 | 08:01 PM
Tom454's Avatar
Tom454
The two ears that the shock support go through are part of the spindle support casting. The first one I worked on, I broke the ear off the spindle support by trying to use a puller on the "nut side". The ear snapped right off... I still have that broken support as a reminder. The shock suppport can be easy to remove, or extremely difficult to remove. If the suspension is rusty, the shock support "rust welds" to the spindle support. That is what happened in my case. It took an oxy/acytelene torch and a big hammer to get mine off... both sides were rust welded. They had not devised the thread saving tools at that time... about 1976. So I mangled the threads on the shock support. Ended up buying a new spindle support and two new shock supports. It was an expensive lesson.
Old May 23, 2012 | 08:51 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Originally Posted by MikeKey
No I mean this part here:
PS: I already removed the shock. But I was planning on getting new Adjustable Strut Rods from VBandP tomorrow when I pick up my composite spring and replacement sway bar since mine is cracked.
http://www.vbandp.com/C2-C3-Corvette...rged-ends.html
That's the shock mount.
Just cut it and buy new ones.
Old May 23, 2012 | 09:31 PM
72LS1Vette's Avatar
72LS1Vette
The problem on many of these cars is that there is a metal sleeve in the torque rod bushing that rust-welds itself onto the shock mount. When this happens it is just about impossible to get the shock mount out without destroying it. It really is worth the $ that the new mounts cost to avoid the time and aggravation that it takes to try to get the old mounts off intact. Not to mention the possibility of breaking the bearing carrier and costing even more $.
If they are extremely stubborn just SawZall them off and replace them. Believe me, the people who talk about getting them off easily are in the minority.
Rick B.
Old May 24, 2012 | 09:26 AM
Tom454's Avatar
Tom454
Rick B.
Old May 24, 2012 | 10:29 AM
Roco71's Avatar
Roco71
Rick B.
I used a cut off wheel as per Rodger's instructions
Old May 24, 2012 | 11:23 AM
MikeKey's Avatar
MikeKey
Do tell, I think I will have to use my cutoff wheel as these look fused. And I want to get everything back together this weekend as more parts arrive.
I already have new mounts to replace the one I'll be cutting.
I did read your comments over in: http://forums.corvetteforum.com/c3-t...over-tool.html
Old May 24, 2012 | 12:44 PM
Roco71's Avatar
Roco71
Hey Mike,
I got to do a little digging to find it when I do I will post it.
Scott
Old May 24, 2012 | 12:49 PM
Roco71's Avatar
Roco71
Here is the link with Rodgers method. I did mine while still on the car.
http://forums.corvetteforum.com/c3-t...ock-mount.html
Old May 24, 2012 | 04:33 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I think I used a reciprocating saw on mine, just ran the blade down the inside of the ears.
Old May 24, 2012 | 07:12 PM
MikeKey's Avatar
MikeKey
Thanks so much Roco71, made my day a lot easier. Started cutting with success. This should work! More parts arrived. Can't wait to post some progress photos of the new improvements and work done.
Old May 24, 2012 | 07:16 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Make sure you coat the shock mounts (and T/A bolts, and the inner strut mount bolts) with anti-seize so they don't rustweld together again.
Old May 25, 2012 | 08:36 PM
  #33
yyz1970's Avatar
yyz1970
It took me a weekend to get mine off
penatrating oil....heat.....and a claw type puller
and a lot of patience...the patience saved the parts from bubba mania
Old May 25, 2012 | 10:19 PM
  #34
MikeKey's Avatar
MikeKey
I bought a cutting wheel, put it on my die grinder and popped those bastards off in about 20 minutes.
Old May 26, 2012 | 07:38 AM
  #35
Roco71's Avatar
Roco71
Old May 26, 2012 | 01:10 PM
  #36
ashes0's Avatar
ashes0
Used a sawsall with a diamond cut blade
Old May 26, 2012 | 03:31 PM
  #37
briankeery's Avatar
briankeery
Mike, would you mind posting a few shots please of the rusted parts that are now removed, so we could see the extent of the damage?
Brian
To Strut Bar Removal Help
Old May 26, 2012 | 04:01 PM
  #38
MikeKey's Avatar
MikeKey
Brian
I didn't get as many usable photos with my iphone as I had hoped...
As to one of my other threads, see how greasy the pumpkin is. Ugh.
Free on both sides. Waiting on my parts from Vette Brakes. Hoping mid week. Once I get the rear cleaned up, I'll be changing the rear fluid out.
Old May 26, 2012 | 04:24 PM
  #39
MikeKey's Avatar
MikeKey
I'm using a two spare jack stands to hold them up for now until I can reinstall everything. Going to clean it all and POR-15 some parts, along with the frame before the tank goes back in the car.
And a photo of the collection of the parts that I've got so far. Still waiting on a few more things. Got everything to put the tank back in this weekend, just want to finish cleaning and prepping the back side before putting her in.
Old May 26, 2012 | 04:41 PM
  #40
MikeKey's Avatar
MikeKey
BIG THANKS FOR EVERYONE WHO HAS HELPED ME. I appreciate it very much.
