Alternator Hmmmmmmmmmm
Old May 22, 2012 | 09:38 PM
kansas123's Avatar
kansas123
Default Alternator Hmmmmmmmmmm
I searched for this problem and solution but only came up with problems with radios that hum. So what is going on with the '72 is that my alternator crapped out so I replaced the diode, voltage reg, brushes and capacitor and cleaned it up. It works great now except that it hums. Before it crapped out, it did not hum. Hmmmmm.....
Old May 22, 2012 | 09:40 PM
oldalaskaman's Avatar
oldalaskaman
radio filter
Old May 23, 2012 | 08:30 AM
kansas123's Avatar
kansas123
So the radio is causing the alternator to hum? even with the radio is off?
oh, and GO ALASKA lived there for 3 or 4 years as a tot.
Old May 23, 2012 | 08:34 AM
oldalaskaman
sorry re-read your thread, you're saying the alternator itself hums . it may take a bit for those new brushes to smooth out. did you undercut the mica?
Old May 23, 2012 | 09:55 AM
kansas123's Avatar
kansas123
The brushes, ok. did not expect that. it should go away then... what does undercut the mica mean? thanks.
Old May 23, 2012 | 10:10 AM
oldalaskaman
the part that the brushes ride on is the comutator, there are separations 'those small lines', the 'mica', that fill with crud from the brushes, rebuilders will clean those out with a small dremel like grinding wheel, it makes it work better and last longer. I take a small pick or knife and manually scrape them out, have to be carefull not to scratch the surface.
Old May 23, 2012 | 11:01 AM
Peterbuilt's Avatar
Peterbuilt
Your thinking about an armature, it has a commutator and mica, an alternator has a rotor and smooth slip rings.
Old May 23, 2012 | 11:04 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
You could also have a belt or pulley issue. I chased an alternator hum for almost a year. It was a bad (out of round) pulley.
Old May 23, 2012 | 11:55 AM
oldalaskaman
you are right, crs kicked in again
Old May 29, 2012 | 12:24 PM
kansas123's Avatar
kansas123
Default i suspected this all along
So to put a fork in this..........it turned out to be a small vacuum leak, not the alternator. i was trying to put all the load on the alternator that i could so i was turning on everything and when i turned on the wipers, (even though they are mainly vacuum operated), the noise went away. thanks for all the inputs though....
To Alternator Hmmmmmmmmmm
