Engine Frame Mounts
Old May 27, 2012 | 09:41 AM
8valve's Avatar
8valve
Default Engine Frame Mounts
Yesterday, I went inspect and pick up a frame for my 73 that was said to be like new. It was not, serious rust inside the trailing arm areas. So my search continues.
My 73 has a 350 engine.
Are the engine mounts both fore/aft location and width spacing the same on a frame for either a small block or big block. Sure dont want to buy a big block engine frame if it wont fit my small block
8Valve
Old May 27, 2012 | 02:04 PM
Alan 71's Avatar
Alan 71
Hi 8v,
The frame is the same for a sb or bb engine.
The only differences in the frame are whether it was built for a 4-speed or an auto transmission.
Regards,
Alan
Old May 27, 2012 | 02:38 PM
8valve's Avatar
8valve
Originally Posted by Alan 71
Hi 8v,
Regards,
Alan
Thank You, Alan
8Valve
To Engine Frame Mounts
