79 propane carb adjustments
Old May 30, 2012 | 11:20 PM
79gilv's Avatar
79gilv
Default 79 propane carb adjustments
I'm just getting into the new toy (79 L48), and preparing for smog in CA. One of the adjustments I may need to make is the idle mixture. The manuals, I have, reference a Propane Enrichment Idle Mixture Adjustment which requires a "special" propane tool. What have any of you wizards used for this function?
Old May 31, 2012 | 12:50 AM
Vette5.5's Avatar
Vette5.5
No propane expert here, but do know it's a way to pass the sniffer without cat converters. You may want to check with the local air resources board before spending a lot of tuning time, as many CA areas have visual inspections. This means 100% as it came from the factory, including single cat converter and air pump. Sure others will chime in.
Old May 31, 2012 | 08:18 AM
bashcraft's Avatar
bashcraft
Are you sure it says propane?
Old May 31, 2012 | 09:21 AM
79gilv's Avatar
79gilv
Yes gentlemen, the manual indicates for 78-79 the only method of adjusting the idle mixture involves the use of a propane tool (GM J-26911). This procedure is not usually needed but the previous owner had "someone" work on the vehicle and I may need to make an adjustment. In speaking with an older smog tech, I have learned that this is in fact the case. Due to some fuel substitution process of which I am only mildly familiar, the adjustment process involves propane. I am hoping some adventurous member has already done this and can provide some guidance.
Old May 31, 2012 | 09:36 AM
69 Chevy's Avatar
69 Chevy
There are literally a gazillion '79 owners on this forum. They're always here asking questions. I'm sure at least a hundred will come to your aid with a suitable answer. Just wait.
Old May 31, 2012 | 10:39 AM
Mike Ward's Avatar
Mike Ward
Google is your friend
http://www.ebay.com/itm/ws/eBayISAPI...vip=true&rt=nc
Old May 31, 2012 | 10:45 AM
oldalaskaman's Avatar
oldalaskaman
I'm to old of a dog to learn that trick.....whew
Old May 31, 2012 | 11:53 AM
79gilv's Avatar
79gilv
I might be too. The idea of becoming a carb expert is not nearly as appealing as driving the toy.
Old May 31, 2012 | 12:36 PM
...Roger...'s Avatar
...Roger...
Are your idle mixture screws accessible,can you see them ?
Old May 31, 2012 | 07:25 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Propane tool? How 'bout natural gas?
Natural gas burns clean too and would help u pass smog but is difficult to get into the carb. You would need a collector hood inside the passenger compartment and a little 12V DC compressor pump running off the cigarette lighter to force it into the carb. This system works most effective after a meal at Taco Bell. I heard the Chinese have adapted this to livestock pens to run a stove, furnace or whatever - corvette could be next.
cardo0
Old May 31, 2012 | 09:11 PM
72LS1Vette's Avatar
72LS1Vette
I had a 1985 Dodge Caravan that had a messed up carb the day I took delivery. The dealership tweaked the carb so I could at least drive it and then they finally found the real problem. When they adjusted the carb back to spec I saw a grille-sized bottle of propane on the shop floor and a hose running into the engine bay.
I think there may be a special port on your carb (if it's stock) for a propane tank hookup. I have no idea what the propane is used for while tuning but apparently it is needed to get the stock carb adjusted properly. Good luck finding the fitting.
Rick B.
Old May 31, 2012 | 09:23 PM
79gilv's Avatar
79gilv
Yeah, I read the tech directions and it is a bit of a process. Anyway the Adjusting screws are visible (nearly) from the front of the carb using a flashlight and a small inspection mirror. They are small hex head screws in recesses at the front. The special PEIM procedure is listed as strictly for the 78-79 carb instead of the standard seat and back-off process indicated for the 72-77 model. Anyone got anything inovative?
Old May 31, 2012 | 09:33 PM
'75's Avatar
'75
It's called propane enrichment.
http://www.thetoolwarehouse.net/p-4452-otc-7148.aspx
http://ezinearticles.com/?Procedures...hod&id=1395808
Old May 31, 2012 | 09:43 PM
...Roger...
Sounds like the plugs or caps have been removed exposing the mixture screws. Is that OK in CA. ?
Old Jun 1, 2012 | 12:20 AM
79gilv's Avatar
79gilv
Thanks '75, that's what I found too. Roger, the missing caps are the reason I think someone messed with the mixture in the past. I am working through the system and am hoping to have a less expensive tool option if I end up needing to adjust the idle mixture. The E-_ _ _ link above is a vintage tool @+/- $75 which still seems high for something I hope I'll never need again. We all know I most likely will do this again at some point, so I might just bite the bullet at this point.
Old Jun 1, 2012 | 08:30 AM
damoroso's Avatar
damoroso
Alot of guys replace those idle mixture screw for the regular kind or pull them and cut a slot in them....just a thought...
Old Jun 1, 2012 | 09:00 AM
79gilv's Avatar
79gilv
.... just a great thought... Thanks for the tip
To 79 propane carb adjustments
