Heater temperature door
I have removed heater hose from the vacuum circuit in order to eliminate the leak. Is there any way I can check the position of the temperature door in order to have only cold air? Now that it's summer it is getting very hot inside!!!!
I believe you'll find that the hot/cold control is a cable connection, not a vacuum connection.
On my 71 when I turn the right-side control wheel from H to C I can hear the door in the heater box open and close.
Perhaps your's still works or can be repaired?
Regards,
Alan
