Combustion chamber size.
Old Jun 7, 2012 | 08:54 AM
540 vette's Avatar
540 vette
Default Combustion chamber size.
What is the combustion chamber size for a 1980 L 48 engine.
Old Jun 7, 2012 | 08:59 AM
speedreed8's Avatar
speedreed8
probably 76cc if the heads are the original smog ones.
Old Jun 7, 2012 | 09:31 AM
540 vette's Avatar
540 vette
Yes original smog ones. Now how much raise in compression if I go to 64cc heads.
Old Jun 7, 2012 | 10:47 AM
7T1vette's Avatar
7T1vette
If still using the dished pistons, also, changing heads would get you about 9.4 or so.
Old Jun 7, 2012 | 11:06 AM
540 vette's Avatar
540 vette
Thats what I need to put the Performer RPM package on my car.
Old Jun 7, 2012 | 11:11 AM
billla's Avatar
billla
St. Jude Donor '14
Rule of thumb for a GEN I SBC is about 1 pt CR for each 10cc change in combustion chamber size...assuming the same gasket (and so, quench) is used.
Most head changes on stock GEN I's use the FelPro 1094 gasket to establish the appropriate quench - a bit of searching on here will give you all the background you need.
Old Jun 7, 2012 | 11:17 AM
540 vette's Avatar
540 vette
Will the 1094 work with aluminum heads.
Old Jun 7, 2012 | 11:25 AM
billla's Avatar
billla
St. Jude Donor '14
Yes; it's a rubber-coated MLS gasket and works with anything.
Someone will pop up and say it requires an extremely smooth block and head deck; they're confused about the difference between an MLS gasket and a rubber-coated MLS gasket like the 1094 which is much more tolerant of a rougher stock-type deck.
To Combustion chamber size.
