I have a Reeds solid roller cam in 468 BBC. I had the engine rebuilt a few months ago. At that time I didn't have cam specs. Engine builder set valve last at 0.016". Just found cam specs on Internet and it says to set valve lash at 0.026". That sounds really large. Engine runs fine at 0.016".
Trying do decide if I should adjust them to 0.026", or leave at 0.016", or somewhere in between.
One advantage would be increased vacuum. At idle it only has 5.5"Hg.
Valve train is pretty quiet (as expected with tight gap).
I wouldn't change anything until you either locate the actual cam card or talk to him and/or the cam company to make sure you have the right info. Websites can list bad info sometimes.
Reed cams have needn't gone long enough that there is no way that that cam runs a 0.016" valve lash, I would at least bump it up to 0.022"int/0.024"ehx clearance
So called "tight lash" cams have only been around 25 years, I hope the roller lifters are top quality. You should check out the Chevelle tech forum for a good data base of big block owners who run solid rollers.
You won't hurt anything running .016" or even tighter. But as you mentioned..vacuum can get better as you loosen them. Often the clearance ramps are pretty long and there isn't much difference in sound at .022" or so..but most likely a little louder.
Remember..cold lash with aluminum heads is set about .005-.06" tighter than hot lash..which is what all cam card say.
.020 cold is the tightest Id go.(ran best I think at .022 cold) leaves hot about 25, 26 which is just about right if that helps. If you do go real "tight" let it really warm up good before you start revving/driving it. If the cam was designed for a fair amount of lash it surely wont hurt anything. Besides who doesnt love the sound
My 468 had a cam motion soild roller. Springs were 1.625 and came with the AFR heads. I ran Isky red zone lifters, and ran .025 lash int and exh. cam was .692/.684 with .262/.272 @.050. motor made 708 hp ran to 7400 rpm.
Solid LT1 is the winner. The help I've gotten from the forum has always been great. Thanks to you guys with the experience for taking the time to help us beginners.
