Who Makes C3 High Performance Mufflers
Old Jun 19, 2012 | 06:39 PM
Les's Avatar
Les
Originally Posted by Ricknhis69
Just a word from my own experiences. Keep in mind that if you want to hear the sound that you will get from a muffler on a C3 you will need to listen to it on a C3. Since there are virtually no tail pipes on these cars any muffler will sound different/louder than it would on say a Chevelle.
Good luck!
Very true. Also, headers vs. stock exhaust manifolds makes a difference. Different motor types can play a role too- i.e. a low comp. w/ mild cam vs. high comp. w/ hot cam will sound different to some degree. Try to listen to a Vette with a comparable motor if possible but that's not as critical as the point made by Rick.
Old Jun 20, 2012 | 08:11 AM
spikebot 81's Avatar
spikebot 81
Spikebot81 - What baseline performance numbers were used to base those numbers on? Was is a 350CI/350HP engine? Great info!
Limey 1955, I found this info 3 or 4 years ago on ls1 website but looks like the test was on a 5 liter mustang. Here is a post from ls1
Quote:
Originally Posted by FAST LS1
So I'd assume they probably did the muffler comparisons right off the headers.
The test was done in 5.0 Mustang Magazine December 2002 issue (page 55) if anyone happens to have a copy and can clear this question up.
It was a chassis dyno. . . those are RWHP numbers from a Notchback w/ heads/cam and bolt-ons.
I think they lost hp w/ no mufflers becuz they didn't mess w/ the fueling to accomodate the new flow.
On another note, the Borla XS is my favorite. . . it was their favorite in the article too, and that's what I'd go w/ on a custom cat-back.
Mike
'98 Z
Old Jun 20, 2012 | 12:48 PM
Ricknhis69's Avatar
Ricknhis69
Learned it the hard way, unfortunately.
There is no better substitute than hearing it in person on the right type of car. Numbers are great but they won't tell you if there are any adverse affects of a particular muffler. The biggest one being what some people call "droning" that seems to be common with performance mufflers. Very annoying and something you want to avoid. Overall volume is one thing but I think its more important to avoid ending up with something that is annoying to listen to at certain RPM's.
I recommend making it to a car show with a lot of C3's if possible, like Bloomington Gold this weekend. It helps if you can talk to other drivers as well as exhaust characteristics change constantly while driving. Don't be in a hurry, you'll live with this one for a long time.
Old Jun 21, 2012 | 01:11 AM
Ralphbf's Avatar
Ralphbf
Mike
'98 Z
Carol Shelby Used Borla and he did alright with them.
Maybe some day I'll give them a try.
R~
