replacing wheel caliper seals
Old Jun 16, 2012 | 07:50 PM
73C34me's Avatar
73C34me
Default replacing wheel caliper seals
how does fit the pistons with new seals into the wheel cylinder caliper bore, without tearing the seals?
Old Jun 16, 2012 | 08:32 PM
7T1vette's Avatar
7T1vette
Wipe them and the caliper bores down with a little brake fluid, first. Then, just work slowly and carefully. Stay patient.
Old Jun 16, 2012 | 08:35 PM
...Roger...'s Avatar
...Roger...
There is a tool that is a plastic tapered cylinder that you feed the piston down and then in to the caliper. I never liked it. I have a thin soft piece of plastic that I shoehorn the seal in with. Put the piston in the bore with half the seal in ,then using the plastic gently fold the seal in and push the piston in.
I'll get you a pic of my homemade installer.
Old Jun 16, 2012 | 08:37 PM
damoroso's Avatar
damoroso
You can use a thin piece of firm wire, shaped into a loop to push the lip seal into the bore can help too.
Old Jun 16, 2012 | 08:58 PM
...Roger...
Looped wire also works,trick is no sharp edges and thin.
I think I made this out of a plastic lid like goes on a coffee can.
Old Jun 18, 2012 | 08:22 AM
73C34me's Avatar
73C34me
thanks for the tips. now I just need to get a couple of seals, hopefully without having to purchase the dust boots too!
To replacing wheel caliper seals
