rear suspension
I've researched shock replacement on this forum somewhat and I've read a few posts about the shocks being extremely difficult to remove, and mentions of special tools, cutting, etc. From what I can see in the Haynes manual and just from looking it seems like you just remove two bolts and swap the shock with a new one, but I'm a total newb and never worked on cars - though I've replaced motorcycle shocks/springs.
I want to order new shocks today (Bilstein HD seems to be highly recommended here) and am wondering if I should order any accessory parts? All the rubber bushings in the rear suspension look shot so I'd like to replace them all of it is feasible to do myself. Also, I can't tell if my leaf spring is in okay shape or if I should just replace it now. The layers between the metal are fraying but I dunno if that matters.
My corvette is my daily driver whenever the weather is nice so I want to minimize down time. I have no plans to race it so I don't need anything fancy but I don't mind paying for quality stuff that will last.
Any advice on tools/parts that I might need, and any tips? I could take it to a shop to get this done I guess but I'd rather do it myself if it isn't too hard.
Vansteel has a suspension rebuild kit but it's pretty expensive so if I don't need all that stuff I'd rather spend the money elsewhere.
rebuild kit:
http://www.vansteel.com/index.cfm?fu...&SubGroup=1865
shocks:
http://www.vansteel.com/index.cfm?fu...&SubGroup=1882
here's some pictures of the passenger side suspension parts:
Be careful. It's easy to get carried away when you start a job like this.
You can spend a lot of money on your car. And by making different compromises than the factory engineers, you can make your car different. It's not too easy to make it better.
Good luck. Be careful. Have fun.
I can get a real service manual if the Haynes isn't good enough.
With that being said, the OP's rear does appear to need ... well .. everything.
Question about shocks, though. I saw a post from VanSteel ~2010 saying that Bilstein HD's aren't manufactured anymore and they are no longer listed on the VanSteel site. I do see them various other places... are these still easy to come by or likely sold-out and not updated? If unavailable, any other high quality rear shock recommendations for a street car?
I'll think about front end in the near future, it isn't as rough as the rear.
http://www.zip-corvette.com/ProductD...GR-SR&CTitle=&
On the Bilstein HD's, I'd recommend you go ahead and grab a set if you can find them, as they're one of the top 5 best upgrades most will ever make to their C3. As for options, KYB's are a decent value, tho not quite on par with Koni's or QA1's, and a few have found Edelbrock's to their liking.
Before you get too discouraged, you might find it inspirational to check out a few suspension rebuild threads posted by other CF'ers. Whether you choose to upgrade or simply restore things (different topic), do it up right and the results are going to be well worth the effort.
Tear Down.....
http://forums.corvetteforum.com/c3-t...down-pics.html
Clean up.....
http://forums.corvetteforum.com/c3-t...hase-pics.html
Re-assembly
http://forums.corvetteforum.com/c3-t...mbly-pics.html
My AIM hasn't been delivered yet...
I'm still going to redo my rear, but I'll be pissed if I do all this and the noise is still there. I can push down and bounce my car up and down from front and rear while parked with no noise, it only happens when I go over small potholes or rough patches in the road.
Also, don't buy your Blistien's from Zip, or any of the other Corvette places, they're also selling them over priced. I matched the same ones for 20$ less with Amazon Prime free shipping.
VBP is also running a sale right now on spring kits and the strut bars. The rear spring if you go composite is usually $360, right now they're $314.
My rear-end looked just like your's the shocks where actually easy with a rubber mallet to remove. The hard part was getting the stupid struts off my car.
Once I got the major crap off it looked like this:
The one part I didn't need to service where the trailing arms on my car. They looked as though they'd been done in the past as the bushings where all very new in appearance and in god condition.
Everything goes back together easily enough. Good luck!
Also, trust me when I tell you, YOU can do this. It's gonna SUCK, because it's hot as ***** out right now, but so long as you can get past that, for the most part, rebuilding the rear is actually....kinda relaxing, almost therapudic, in a way. EXCEPT for the rear shock mount. The rear shock mount can go to hell, for all I'm concerned. And the bushings on the TAs. Plan a day JUST for those TAs...not PHYSICALLY hard, just frustrating. Highly so. Take your time, any part you are gonna reuse, hit it with the drill/wire brush bit combo to clean it nice, paint it, and when you are done, it's gonna look good as NEW, you're gonna take pictures, post them here, and everyone is gonna congratulate you on a FANTASTIC job, and all the new people to the forum are gonna look and lament about your superior mechanical skills, etc. Take that, combine it with a beer, and trust me, you're gonna feel pretty good.
I broke one in my 75 while hot rodding! It's no fun let me tell you the the wheel just collapses into the wheel well at speed in a turn....Everything is mostly bolt on except the control arm bushings but if they're not bad, just bolt on spring, shocks and all the other bushings you can get too.
It's a good call to do it yourself, and you're not gonna regret it, I promise.
Just make sure that you take your time, and plan the work. As in, when you get your stuff, see what all you have, and what all you are going to need to reuse. For instance, the kit I ordered, came with everything BUT the rear shock mounts. I nearly screwed myself out of a couple of bucks, and a couple of days of work, due to that...because, I banged the CRAP out of those things to get them out, WITHOUT a nut or anything on the threads to protect them, which in turn made putting a NEW nut on them, with the new shocks in place, pretty hard. A little filing and a little patience saw me through that, but you can bet I was a LOT more careful there after!
Also, from what I've been reading here replacing the trailing arm bushings properly (rubber) requires a hydraulic press and either buying or fabricating a custom tool. Is this correct? If so I guess I'll have to send them out if they're shot.
I'll look at them out with a flashlight tomorrow and check for play when I do the other work.
