Hanging Plug
Old Jun 21, 2012 | 03:14 PM
alankirsh's Avatar
alankirsh
7th Gear
Default Hanging Plug
I need some help. I noticed a round plug hanging in the drivers side of my engine comparment. The two wires are Yellow and Black. the plug is round and the female Slots look like (l -). I am not sure where this plug goes. Maybe an Oxygen sensor???? I would appreciate any help. the engine is an L-48, 1975 Corvette Convertible. If you know, please email me at: alankirsh@gmail.com.
Thank you
Old Jun 21, 2012 | 04:05 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
Thank you
PHOTO ?
Maybe water temp sending unit ?
Old Jun 21, 2012 | 04:14 PM
Roco71's Avatar
Roco71
Can you post a photo? Is your car a automatic or manual.
Old Jun 21, 2012 | 04:24 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
No O2 sensor on a 75. Try the theft alarm switch.
Old Jun 21, 2012 | 09:41 PM
my 76 ray's Avatar
my 76 ray
I was thinking theft alarm also because of the description of the plug.
Old Jun 22, 2012 | 01:03 AM
alankirsh's Avatar
alankirsh
7th Gear
Default unplugged
I checked the alarm and that is fine I will post a pictue of the plug later.
Old Jun 22, 2012 | 01:04 AM
alankirsh's Avatar
alankirsh
7th Gear
I will check thanks!
Old Jun 22, 2012 | 07:17 AM
Roco71's Avatar
Roco71
The way that you have described the plug end its sounds very much like the plug for the transmission kick down. The line would have to be long enough to reach the middle of the transmission. The wires on my 71 kick down are orange and black but the orange turns yellowish after years of being exposed to heat.
My first thought
Old Jun 22, 2012 | 11:16 AM
alankirsh's Avatar
alankirsh
7th Gear
My first thought
Thank you, I will look at the transmission tonight.
Old Jun 22, 2012 | 12:26 PM
...Roger...'s Avatar
...Roger...
Could be for the small black anti tamper switch for the fender alarm key switch.
The alarm would still work fine as long as nothing is plugged into the 2 wires.
Look at this thread,it shows the little switch,same switch used in the headlight doors.
http://forums.corvetteforum.com/c3-t...questions.html
Old Jun 22, 2012 | 04:53 PM
Roco71's Avatar
Roco71
Rodger, that's sounds a lot more likely than the transmission "kickdown" but I believe the spades are the same.
To Hanging Plug
