Speedometer
Old Jun 25, 2012 | 03:13 PM
AV8RSVT#1's Avatar
AV8RSVT#1
Default Speedometer
My speedometer works however my odometer and trip odometer do not. any ideas?
Old Jun 25, 2012 | 04:03 PM
MelWff's Avatar
MelWff
The problem is internal to the speedometer and has to be removed. You are sure the reset **** below the dash is fully down?
Old Jun 25, 2012 | 04:22 PM
7T1vette's Avatar
7T1vette
The odometer "reset" ****/cable may be stuck in the 'down' position so that the internal gears cannot mesh. Push the reset **** 'up' and see if it moves further. If not, then the internal gear set has a failure of some kind and the head will have to be repaired or replaced.
Old Jun 25, 2012 | 04:48 PM
AV8RSVT#1's Avatar
AV8RSVT#1
Default odo reset
Sorry its a "72" Where is my odometer reset??
Old Jun 25, 2012 | 05:00 PM
MelWff's Avatar
MelWff
right under the steering column, this is what the complete assembly looks like
http://www.ecklerscorvette.com/corve...1968-1977.html
To Speedometer
