Advice needed on loose steering
Old May 26, 2002 | 01:19 AM
jwatty's Avatar
jwatty
Default Advice needed on loose steering
Anyone familiar with the procedure to take the "play" out of my 82s steering? The wheel moves a little more than I like before it catches and the wheels react.
Old May 26, 2002 | 01:48 AM
45ACP's Avatar
45ACP
http://www.corvettefaq.com/steering.asp
Look for "Steering Gear Adjustment".
Old May 26, 2002 | 02:35 AM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Default Re: Advice needed on loose steering (jwatty)
I would also look into a front end rebuild. $199 for the kit. Takes awhile, but it's worth it. A new idler arm will help wonders. If you go the extra mile and swap out the ragjoint, you won't be disappointed.
Old May 26, 2002 | 05:57 AM
mrvette's Avatar
mrvette
Even if the steering is 100%, tite as new, which mine was, the differance of feel between stock and a rack and pinion setup is astounding....differant car entirely....not even worth redoing the stock setup, just not worth it....
GENE :D :D :D :D :cool:
To Advice needed on loose steering
