backfire?
Old Jun 28, 2012 | 11:35 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Default backfire?
I'm getting backfire when I accelerate close to WOT, then let off the throttle. Not a pop either, much louder
What normally causes this?
Old Jun 28, 2012 | 12:33 PM
bluedawg's Avatar
bluedawg
Only at wot. Sounds like a lean issue.
Old Jun 28, 2012 | 01:03 PM
Mike Ward's Avatar
Mike Ward
Too much vacuum advance.
Old Jun 28, 2012 | 01:07 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Back off timing or vacuum canister needs replacing/fixing?
Old Jun 28, 2012 | 01:10 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
My vacuum canister is sharing it's vacuum with other items, does this factor into it at all?
Old Jun 28, 2012 | 01:46 PM
Mike Ward's Avatar
Mike Ward
Disconnect and plug the vacuum line from the distributor just for troubleshooting, see what happens.
Old Jun 28, 2012 | 03:11 PM
plaidside's Avatar
plaidside
Does it pop out the exhaust, after fire, or up through the carburetor, back fire?
Does it 'pop' when you are accelerating or only when you let off the throttle and are decelerating?
If only on decelerating then I would suspect an air leak in the exhaust.
Old Jun 28, 2012 | 11:10 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Is she popping on acceleration or deceleration?
Old Jun 28, 2012 | 11:45 PM
gve's Avatar
gve
A worn cam lope can cause that noise
Old Jun 29, 2012 | 08:13 AM
Vette5.5's Avatar
Vette5.5
As mentioned, gotta be some kind of timing/ignition problem. Good idea pulling a few things apart, as the nylon quiet cam gear, is known to be a problem over time. If this is warn to the point, the chain starts jumping teeth, could be some walking in your near future.
Old Jun 29, 2012 | 10:05 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Exhaust + decel.
removed vac line to canister, backfire gone, as is off idle stumble.
Old Jun 29, 2012 | 02:20 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
How exactly do I cure "too much vacuum advance"?
Old Jun 29, 2012 | 02:47 PM
Mike Ward's Avatar
Mike Ward
First find out how much you've got and why- wrong vacuum can, missing limiter bushing etc. IOW- map the advance curve, I think Lar's papers cover this.
Old Jun 29, 2012 | 08:17 PM
scottyp99's Avatar
scottyp99
Here's some good info on how timing works:
http://forums.corvetteforum.com/c3-t...long-post.html
Keep the shiny side up!
Scott
Old Jun 30, 2012 | 12:16 AM
73, Dark Blue 454
Originally Posted by moonsteel
Exhaust + decel.
What "canister"? Sounds like you found a vacuum leak.
Old Jul 4, 2012 | 11:50 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
the canister on the distributor
Old Jul 4, 2012 | 12:27 PM
lars's Avatar
lars
You set up your timing and vacuum advance as outlined in my papers. E-mail me if you need copies of the timing paper and vacuum advance paper - specific instructions for altering the length of the timing curves are in the papers.
Popping in the exhaust is primarily the sign of a lean condition - you're going to want to richen it up in addition to fixing the timing.
Lars
V8FastCars@msn.com
Old Jul 4, 2012 | 01:01 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Lars
V8FastCars@msn.com
I'm using Holley HP EFI for fuel, if I'm not mistaken, during decel the fuel is cut completely.
Old Jul 9, 2012 | 11:53 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Small update (spent my weekend under a buddies 69 Mustang).
My vac canister says "B9", which (if I'm not mistaken) is a VC1605.
I made only one change this weekend, turned on Decel Fuel Cut. Backfire is much less violent and happens less often as well.
Next step, recheck my timing.
To backfire?
