correct thermostat?
Old May 26, 2002 | 06:26 PM
Ryan77's Avatar
Ryan77
Default correct thermostat?
I went to autozone to get a new thermostat and housing last night, the guy gave me a 195 degree thermostat and said that was the correct one. My friend told me that I should be using either 180 or 185 degree thermostat. Any thoughts? What do you guys use?
Old May 26, 2002 | 06:29 PM
shotgun_000's Avatar
shotgun_000
Default Re: correct thermostat? (Ryan77)
I use a 180 year round, and have no problems. Be sure to buy the good thermostat, and not the $3 AutoZone brand. The good ones are about $6, and have a lifetime warranty.
bence13_33's Avatar
bence13_33
The guy at the auto store was correct, stock thermostats were 195 degrees. I would personally run a 180 thermostat. A 180 will open up sooner and will keep the temperature under control...for a while. Ultimately your engine will eventually reach it's desired temperature regardless of the thermostat. I would personally run a 180, that's what I had in my 350.
Old May 27, 2002 | 01:35 AM
EarnIt's Avatar
EarnIt
The owners manual for a 77 lists a 195 degree thermostat but I have a 180
in mine and it works just fine. Temp. only reaches 200 on 90 degree days
and runs at 180 on all others.
To correct thermostat?
